iLogic - Insert Autocad Block into IDW sheet
02:11 PM
I am looking for some help with using iLogic to insert a Drawing resource of an AutoCAD block onto a sheet in an IDW. I am able to use iLogic to remove an existing Inventor title block from my sheet. I then want to insert a saved AutoCAD block of a different title block onto the sheet. At this point, I have not found the right code to start that process.
I am using the AutoCAD Block as when I export this to an AutoCAD DWG file it keep the Attributes linked to AutoCAD fields. If I convert this to an Actual Inventor title block I lose that function.
Mark
