iLogic in an assembly add dimensions to all part properties
Stefan.Rohde
Stefan.Rohde
Hello.
I have an iLogic rule which writes the component dimensions (LxBxH) in iProperties to me. The problem is that the values are written in a line, however, I need a line for one value, so I can use the columns L and B for the surface calculation in the Excel.
Or is it possible to write immediately the surface in m ² in the Iproperties?
Ideally would be an iLogic rule which I could release in the assembly and all parts get the dimensions and surfaces in the Properties written:-)
GeorgK
Hello @Stefan.Rohde,
please post your code to add the missing part.
Georg
Stefan.Rohde
Here ist the Code:
Sub Main ()
Dim oDoc As Inventor.Document
Dim oPartDoc As Inventor.PartDocument
Dim oCompDef As Inventor.ComponentDefinition
Dim oFlatExtent As Boolean = False
Try
oDoc = ThisDoc.Document
If oDoc.DocumentType = kPartDocumentObject Then
oPartDoc = oDoc
If oPartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
oCompDef = oPartDoc.ComponentDefinition
If oCompDef.HasFlatPattern = True Then
oFlatExtent = True
'set the length units string
Units = oDoc.UnitsOfMeasure.LengthUnits
Select Case Units
Case 11269
UnitString = "mm"
Case 11268
UnitString = "cm"
Case 11270
UnitString = "m"
Case 11272
UnitString = "in"
Case 11273
UnitString = "ft"
End Select
If oFlatExtent = False Then
L = Round(Measure.ExtentsLength,1)
B = Round(Measure.ExtentsWidth, 1)
H = Round(Measure.ExtentsHeight, 1)
iProperties.Value("Custom", "Abmessungen_Bauraum") = L & "x" & B & "x" & H & " " & UnitString
Else
L = Round(SheetMetal.FlatExtentsLength, 1)
B = Round(SheetMetal.FlatExtentsWidth, 1)
iProperties.Value("Custom", "G_L") = L & "x" & B & " " & UnitString
iProperties.Value("Custom", "Blechstärke") = oCompDef.Thickness.Expression
'cross section unfolded model
Catch ex As Exception
iProperties.Value("Custom", "Dimensions") = "iLogicRule Error"
iProperties.Value("Custom", "Abmessungen_Bauraum") = "iLogicRule Error"
End Try
End Sub
