iLogic - How to sum a property of all subasemblies with filter
iiiocep
iiiocep
Hi, I have assemly with subassemblies which have custom Property "MyNumber". I found how to sum all properties, but I need to filter some subassemblies in which I want to calculaate sum. Subassemblies which I want to filter have  iProperties.Value("Summary", "Title") = MyNumber2. How can I first filter only subassemblies which have only this parameter and then sum their custom properties ?
'- - - - - - - - - - - sum the custom iProperty - - - - - - - - - -
'clear the custom property in the assembly
iProperties.Value("Custom", "MyNumber") = 0
'set a reference to the assembly component definintion.
'This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components
'(in case a virtual component trips things up)
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
'custom property in the assembly
xNumber = iProperties.Value("Custom", "MyNumber")
'custom property in the parts
yNumber = iProperties.Value(oOccurrence.Name, "Custom", "MyNumber")
sumNumber = xNumber + yNumber
'set custom property values
iProperties.Value("Custom", "MyNumber") = sumNumber
Else
Next
tyler.warner
@iiiocep You can try something like this:
I just added the Try/Catch & If/Then loops within your existing ForEach loop.
For Each oOccurrence As ComponentOccurrence In oAsmCompDef.Occurrences
		Try
			If iProperties.Value(oOccurrence.Name, "Summary", "Title") = "MyNumber2" Then
		Catch
		End Try
Next
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
iiiocep
I have modified a little your code but it stiil dooesn't work correct. I need to sum only mass of  subassemblies which  Contains "Strut" in their - "Summary", "Title" but if I use this code all parts and subassemblies summarize.
 If iProperties.Value(oOccurrence.Name, "Summary", "Title").ToString.Contains("Srtut") then
xNumber = iProperties.mass
iProperties.Value("Custom", "MyNumber") = Round(xNumber,0)
Next
tyler.warner
@iiiocep The .ToString.Contains() was a good replacement of the Try/Catch loop!
In your code above, "Strut" was spelled incorrectly.
Added the mass from the specific occurrence as well.
Dim xNumber As Double
		If iProperties.Value(oOccurrence.Name, "Summary", "Title").ToString.Contains("Strut") Then
			Dim mass As Double = iProperties.Mass(oOccurrence.Name)
			xNumber = xNumber + mass
Next
iProperties.Value("Custom", "MyNumber") = Round(xNumber, 0)
iiiocep
@tyler.warner Thanks a lot, now it works perfect. But I have a new question now, how can I sum mass of parts only from the General assemly without parts from subassemblies ?
tyler.warner
@iiiocep Am I understanding correctly: If you have an assembly with Part1, Part2, Sub-Assembly1, Sub-Assembly2 then you only want the mass of Part1, Part2?
Adding the SubOccurrences.Count (see line 19/20) can figure out if the occurrence is a part or sub-assembly.
		If iProperties.Value(oOccurrence.Name, "Summary", "Title").ToString.Contains("MyNumber2") And _
		oOccurrence.SubOccurrences.Count = 0 Then
Next
iProperties.Value("Custom", "MyNumber") = Round(xNumber, 2)
iiiocep
@tyler.warner You are completely correct understand, it woks perfect! Thank's a lot!
