Ilogic - how to Export Flat Pattern to .SAT
yvandelafontaine
yvandelafontaine
I know how to export a flat pattern as a DXF with ilogic, but how do i export a flat pattern as a SAT file with ilogic?
Everything i tried give me the folded version of it, i need the flat pattern of it...
I have tried DATAIO, oDoc.SaveAs, Any help would be greatly appreciated...
PS: i did try to use flatpattern.edit before saving but it did not change anything...
JhoelForshav
Hi @yvandelafontaine,
You can use the DataIO from the flatpatterns body.
This code assumes that you run it from a part and the part has a flatpattern.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
oDef.FlatPattern.Body.DataIO.WriteDataToFile("ACIS SAT", "C:\Users\hfljf\Desktop\SAT_TEST\satfile.sat") 'Your path and filename
Just replace my save location to a location that exists in your system 🙂
yvandelafontaine
Thank you, it work, actually i found the same solution while you posted.
I was missing the ".body." part
