iLogic: How to create a new PropertySet
j.pavlicek
j.pavlicek
I'm trying to create a New PropertySet object where a new properties will be stored during a Rule.
But I'm getting following error: Object reference not set to an instance of an object.
Tried to declare variable as New, but it causes error (Keyword New cannot be used inside an interface - my translation to EN).
Sub Main()
	Dim iPropSet As PropertySet
	Dim iPropSet2 As PropertySet
		'Logger.Debug("SetCustomIprop Sub")
		iPropSet = ThisAssembly.Document.PropertySets("User Defined Properties")
		Logger.Debug(1)
		iPropSet.Add("value", "name")
		Logger.Debug(2)
		iPropSet2.Add("value", "name") '<---Error is here
		Logger.Debug(3)
End Sub
Thanks for advice.
Inventor 2022, Windows 10 Pro
Sorry for bad English.
marcin_otręba
check this out:
https://modthemachine.typepad.com/my_weblog/2010/04/creating-custom-property-sets-and-iproperties.ht...
you must do something like
ipropset2=thisassembly.document.propertysets.add(your name)
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
j.pavlicek
Of course, it't obvious, I feel embarrassed. I've must been overworked yesterday.
PropertySet is (sub class) of the Document object, which contains its (Document.PropertyClass.Add()). So I need to create this PropertySet as part of some Document object, because it is not defined outside.
Public Sub CreatePropertySet()
    ' Get the active document.
    Dim doc As Document
    oDoc = ThisApplication.ActiveDocument
    ' Create a new property set.
    Dim customSet As PropertySet
    myPropertySet = oOoc.PropertySets.Add("My Stuff")
    ' Add a property.
    myPropertySet.Add("Value", "Name")
End Sub
Thanks for help!
