iLogic - Hide workplanes before save document
alexandre
alexandre
View > Visibility > Object Visibility
Descrição:
When saving parts and assemblies, I would like User Workplanes to always be hidden.
We have a keyboard shortcut "Alt + [", however, I would like to leave the active option of Work Plans always hidden.
I share:
"Dear Alexandre Vieira,
Create a rule with below iLogic code and add to "Before Save Document" event triggers (For reference https://www.youtube.com/watch?v=h38GRrDdfjs).
Dim doc As Document
doc = ThisApplication.ActiveDocument
Dim odef As ComponentDefinition
odef = doc.ComponentDefinition
Dim p As WorkPlane
For Each p In odef.Workplanes
p.Visible= False
Next
 doc.Save()
Best Regards,
CHANDRA SHEKAR G"
WCrihfield
Was there a question?
Does that code not work for you?
That code should work just fine for part documents.
But when dealing with assemblies, you have to keep the "DesignViewRepresentation" in mind.
If the active DesignViewRepresentation is the Master one or a locked one, it will not save those changes.
You need to make sure the active DesignViewRepresentation is an unlocked one, before it will save changes to Visibility.
Wesley Crihfield
(Not an Autodesk Employee)
alexandre
There is no question,
I just wanted to share a solution that was passed on to me and I wanted to share it with the group.
My need was only for parts.
I am also aware of the Design View Representation.
Thank you for your concern,
