ilogic. help needed for creating an edge collection
kesUPRHR
kesUPRHR
i am trying to make a bend with ilogic and i can't figure out how to make an edge collection from to specific edges
can any someone. explain how it works?
thanks in advance
WCrihfield
Hi @kesUPRHR.  You can use the following line of code to create a new EdgeCollection object.  How you fill in some items into that collection is up to you.  Then you can supply that object to the property you were showing.
Dim oEdgeColl As EdgeCollection = ThisApplication.TransientObjects.CreateEdgeCollection
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
kesUPRHR
thank you so much. got my function to work
