iLogic 規則是否可以引用部件中的元件並使用 Component.IsActive = True 或 False 控制其抑制狀態?- Can an iLogic rule reference a component in an assembly and control its suppression state using Component.IsActive = True or False?
Nelsonkc
Message 1 of 1
Nelsonkc
Hello experts,
I'm a student who created four parameters to control which groups of parts are displayed in each of the four directions (front, back, left, right). All parts can be suppressed or unsuppressed based on my parameter selections, but I'm encountering an issue with the parts in Group_LoadPort.
I've already tried changing the part names to both Chinese and English, and I've made sure there are no special characters in the names.
Is this a known issue? If so, could you please offer some guidance or a solution? Any help would be greatly appreciated.
Thank you.
Dim Group_DOOR_上 As Boolean = False
Dim Group_DOOR_下 As Boolean = False
Dim Group_DOOR_左 As Boolean = False
Dim Group_DOOR_右 As Boolean = False
Dim Group_SMIF_上 As Boolean = False
Dim Group_SMIF_下 As Boolean = False
Dim Group_SMIF_左 As Boolean = False
Dim Group_SMIF_右 As Boolean = False
Dim Group_LoadPort_上 As Boolean = False
Dim Group_LoadPort_下 As Boolean = False
Dim Group_LoadPort_左 As Boolean = False
Dim Group_LoadPort_右 As Boolean = False
Dim Group_Aligner_上 As Boolean = False
Dim Group_Aligner_下 As Boolean = False
Dim Group_Aligner_左 As Boolean = False
Dim Group_Aligner_右 As Boolean = False
' 根據您的選擇,獨立判斷並設定每個元件的狀態
' LoadPort
If  = "LoadPort" Then
    Group_LoadPort_上 = True
    Group_LoadPort_下 = True
    Group_LoadPort_左 = True
    Group_LoadPort_右 = True
' DOOR
If  = "DOOR" Then
    Group_DOOR_上 = True
If  = "DOOR" Then
    Group_DOOR_下 = True
If  = "DOOR" Then
    Group_DOOR_左 = True
If  = "DOOR" Then
    Group_DOOR_右 = True
' SMIF
If  = "SMIF" Then
    Group_SMIF_上 = True
If  = "SMIF" Then
    Group_SMIF_下 = True
If  = "SMIF" Then
    Group_SMIF_左 = True
If  = "SMIF" Then
    Group_SMIF_右 = True
' Aligner
If  = "Aligner" Then
    Group_Aligner_上 = True
If  = "Aligner" Then
    Group_Aligner_下 = True
If  = "Aligner" Then
    Group_Aligner_左 = True
If  = "Aligner" Then
    Group_Aligner_右 = True
' 將變數值賦予元件,以啟用對應的設備
' LOAD PORT 元件啟用區塊
Component.IsActive("longup:1") = Group_LoadPort_上
Component.IsActive("shottup:1") =  Group_LoadPort_上
Component.IsActive("longdown:1") = Group_LoadPort_下
Component.IsActive("shotdown:1") =  Group_LoadPort_下
Component.IsActive("longleft:1") = Group_LoadPort_左
Component.IsActive("shotleft:1") =  Group_LoadPort_左
Component.IsActive("longright:1") = Group_LoadPort_右
Component.IsActive("shotright:1") =  Group_LoadPort_右
' DOOR
Component.IsActive("7DLR-0101-005:2") = Group_DOOR_上
Component.IsActive("7S022-0086-0101-038:2") = Group_DOOR_上
Component.IsActive("7S022-0086-0101-039:2") = Group_DOOR_上
Component.IsActive("AP-191-1-A:3") = Group_DOOR_上
Component.IsActive("AP-191-1-A:4") = Group_DOOR_上
Component.IsActive("7S022-0086-0101-057:2") = Group_DOOR_上
Component.IsActive("C-195-0H:3") = Group_DOOR_上
Component.IsActive("C-195-0H:4") = Group_DOOR_上
Component.IsActive("7DLR-0101-005:3") = Group_DOOR_下
Component.IsActive("7S022-0086-0101-038:3") = Group_DOOR_下
Component.IsActive("7S022-0086-0101-039:3") = Group_DOOR_下
Component.IsActive("AP-191-1-A:5") = Group_DOOR_下
Component.IsActive("AP-191-1-A:6") = Group_DOOR_下
Component.IsActive("7S022-0086-0101-057:3") = Group_DOOR_下
Component.IsActive("C-195-0H:5") = Group_DOOR_下
Component.IsActive("C-195-0H:6") = Group_DOOR_下
Component.IsActive("7DLR-0101-005:4") = Group_DOOR_左
Component.IsActive("7S022-0086-0101-038:4") = Group_DOOR_左
Component.IsActive("7S022-0086-0101-039:4") = Group_DOOR_左
Component.IsActive("AP-191-1-A:7") = Group_DOOR_左
Component.IsActive("AP-191-1-A:8") = Group_DOOR_左
Component.IsActive("7S022-0086-0101-057:4") = Group_DOOR_左
Component.IsActive("C-195-0H:7") = Group_DOOR_左
Component.IsActive("C-195-0H:8") = Group_DOOR_左
Component.IsActive("7DLR-0101-005:1") = Group_DOOR_右
Component.IsActive("7S022-0086-0101-038:1") = Group_DOOR_右
Component.IsActive("7S022-0086-0101-039:1") = Group_DOOR_右
Component.IsActive("AP-191-1-A:1") = Group_DOOR_右
Component.IsActive("AP-191-1-A:2") = Group_DOOR_右
Component.IsActive("7S022-0086-0101-057:1") = Group_DOOR_右
Component.IsActive("C-195-0H:1") = Group_DOOR_右
Component.IsActive("C-195-0H:2") = Group_DOOR_右
' SMIF
Component.IsActive("@3S025-9999-1601上:1") = Group_SMIF_上
Component.IsActive("@3S025-9999-1601下:1") = Group_SMIF_下
Component.IsActive("@3S025-9999-1601左:1") = Group_SMIF_左
Component.IsActive("@3S025-9999-1601右:1") = Group_SMIF_右
' Aligner
Component.IsActive("@LPT300-ST1 3D (RD-O3DR-24777)上:1") = Group_Aligner_上
Component.IsActive("@LPT300-ST1 3D (RD-O3DR-24777)下:1") = Group_Aligner_下
Component.IsActive("@LPT300-ST1 3D (RD-O3DR-24777)左:1") = Group_Aligner_左
Component.IsActive("@LPT300-ST1 3D (RD-O3DR-24777)右:1") = Group_Aligner_右
   nini
Replies (0)
