ilogic Get User name: property to custom parameter
j.romo
j.romo
Hello im working on a Ilogic code to set the name of the designer (lets calle him "Dave") working on a part that  was made by other user, and the Designer ("Matt")
The part made By Dave gets  his name from the user name in General Applications\general\User name = "Dave"
but I want this part to be modified by Matt to fill a custom parameter Rev_1 to get the General Applications\general\User name = "Matt" in Matt´s Seat.
So we know Dave made the original part and Matt modified it.
Thanks in advance
JamieVJohnson2
Custom iProperty ('Property' not 'Parameter') should be what you are after.
    iProperties.Value("Custom", "PlotDate&Time")= Now & " " & Time
    iProperties.Value("Custom", "CurrentUser")=System.Security.Principal.WindowsIdentity.GetCurrent.Name
as an iProperty you can use that on a sheet text object by selecting Custom Properties - Drawing, then the custom property.  This example came from my save stamp code that allows a custom border with text that looks like this:
<FILENAME AND PATH>, <CurrentUser>, <PlotDate&Time>
Now, my current user is not a short name, it is the domain user name, but you can write the code to get any value you wish, (in case of a new drawing, take from an existing iProperty, and store in in the custom iProperty so it won't automatically change later).
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
j.romo
Jaimie thanks
that gives me the Computer and name of the User in Windows.
But We want the name of the user name from application options, as shown in the attached image
Some Pcs have Older User names or Generic ones (guys from IT dont like to work much) but each user changes the User Name in application otions directly in inventor. Thats the name I want to get.
JamieVJohnson2
perhaps this:   invApp.GeneralOptions.UserName
j.romo
maybe but how can I use it ?
SyntaxEditor Code Snippet
iProperties.Value("Project", "Engineer") = invApp.GeneralOptions.UserName
this way wont work
JamieVJohnson2
sorry, I'm used to .Net, in ilogic, invApp is the inventor.application you can acquire using ThisApplication (I think).
j.romo
Worked like this:
oNAME = ThisApplication.GeneralOptions.UserName
iProperties.Value("Project", "Engineer") = oNAME
