iLogic: get part number instead file name
Neuzzo
Neuzzo
Hi, i've modify this iLogic macro for my use.
Now the macro compare from an excel file the value of part number in my assembly.
If part match, it write a custom iProp. All works.
But it work on a file name. I need to do it with part number and not the file name. But i don't find the value to get this param.
Can someone help me? Thanks in advance
Sub Main ()
'Create variables'set a reference to the assembly component definintion
Dim oAssDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim ExcelFullName As String
Dim FileName As String
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = oOrigRefName
oFileDlg.CancelError = True
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
ExcelFullName = oFileDlg.FileName
'Open Excel database
GoExcel.Open(ExcelFullName,"DISTINTA BASE")
'Iterate through each referenced document'Dim oOcc As ComponentOccurrence
    For Each oDoc As Document In oAssDoc.AllReferencedDocuments
    ErHa = "Start"
    Try
        'Extract Part Number of active occurrence
        Dim oPropSet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
        oPartNumber = Left(oDoc.DisplayName, Len(oDoc.DisplayName) - 4) '(Left(oDoc.DisplayName) -4)
        'MessageBox.Show(oPartNumber)
    ErHa = "Define custom property collection"
        Parameter.UpdateAfterChange = True
        i = GoExcel.FindRow(ExcelFullName, "DISTINTA BASE", "Part Number", "=", oPartNumber)
		If i = "-1"
			GoTo PROSSIMO
		Dim COSTO As String = GoExcel.CurrentRowValue("Unit price €")
        If String.IsNullOrEmpty(COSTO) Then
        GetProperty(oPropSet, "Costo").Value = ""
        Else
        GetProperty(oPropSet, "Costo").Value = COSTO
		GetProperty(oPropSet, "Tipo ricambio").Value = "C"
    ErHa = "Update the file"
        iLogicVb.UpdateWhenDone = True
        Catch ex As Exception
        MsgBox("Part: " & oDoc.DisplayName & vbLf & "Code-Part: " & ErHa & vbLf & "Error: " & ex.Message)
    End Try
PROSSIMO:
    Next
'Close Excel database
GoExcel.Close
End Sub
Private ErHa As String = vbNullString
Function GetProperty(oPropset As PropertySet, iProName As String) As Inventor.Property
    ErHa = "GetProperty: " & iProName
    Dim iPro As Inventor.Property
    Try
        'Attempt to get the iProperty from the document
        iPro = oPropset.Item(iProName)
    Catch
        'Assume error means not found, so create it
        iPro = oPropset.Add("", iProName)
    End Try
    Return iPro
End Function
This is the function
Danilo "DannyGi" G.
Mechanical design engineer and product developer
Neuzzo
Up?
Danilo "DannyGi" G.
Curtis_Waguespack
@Neuzzo wrote:
Up?
Hi @Neuzzo
Programming questions of this type are better asked on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
You can use the REPORT button to ask the Admin staff to move your post to that forum.
I hope this helps.
Curtis
Neuzzo
Uhm ok, thank you. I ask for a topic move.
Danilo "DannyGi" G.
Curtis_Waguespack
To your question though, I think you can just use this:
oPartNumber = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
I hope this helps.
Curtis
Neuzzo
You're the man! Thank you
Danilo "DannyGi" G.
john.vanderhoven
Hi, sorry dont see how this answers my request.
