Ilogic generate jpg
Ilogic generate jpg
Ilogic generate jpg
Hi
I run a script, while I have a drawing on the screen, which generate pdf (drawing) and step (part). Now I also would like this script to generate a jpg of the part. I found this script that works fine.
https://forums.autodesk.com/t5/inventor-forum/ilogic-save-image-of-model/td-p/6875045
But I would like to start this script while I have my drawing on the screen so the jpg would be made of the part. What are missing in the script to make it possible?
//Goran
Sergio.D.Suárez
With this code you can create an image of the reference document of the view (in my example accessing through the item).
This ilogic is executed from the drawing file.
You must specify well the path where the image will be saved, in micaso the disk "E".
I hope it is useful for you. regards
oPath = "E:\"
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oViewModelDocName As String = Left(oViewModelDoc.DisplayName, (InStrRev(oViewModelDoc.DisplayName, ".", - 1, vbTextCompare) - 1))
Dim m_Camera As Inventor.Camera
m_Camera = ThisServer.TransientObjects.CreateCamera()
If oViewModelDoc.DocumentType = kPartDocumentObject Then
  m_Camera.SceneObject = DirectCast(oViewModelDoc, PartDocument).ComponentDefinition
Else
  m_Camera.SceneObject = DirectCast(oViewModelDoc, AssemblyDocument).ComponentDefinition
m_Camera.Perspective = False
Dim m_TO As Inventor.TransientObjects
m_TO = ThisApplication.TransientObjects
m_Camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
m_Camera.Fit
m_Camera.ApplyWithoutTransition
ThisApplication.DisplayOptions.NewWindowDisplayMode = DisplayModeEnum.kShadedWithEdgesRendering
ThisApplication.DisplayOptions.Show3DIndicator = False
Dim TumbFilename As String = oPath & oViewModelDocName & ".bmp"
m_Camera.SaveAsBitmap(TumbFilename, 800, 600, m_TO.CreateColor(255,255,255))
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Hi
The script works perfectly.
Thanks!
//Goran
kwilson_design
Hello all,
I'm trying to do a simlar task with iLogic and can't seem to get it to work. We have a new webstore we are implementing and they need jpeg's of all the 3D models. I'm trying to find a way to run an iLogic rule on save that will:
  • use the all white background setting (many engineers like to use different display backgrounds but webstore needs to be consistent with all white background).
  • perform zoom extents
  • use the same isometric camera view each time
  • create jpeg on save (doing it upon check-in to Vault would be even better but not required)
  • save jpeg to a specified folder.
I've tried to search for a post similar to my needs and have found bits and pieces of the code for this sort of task but I keeping having failures. I'll admit I'm not the most savvy iLogic coder either lol. Any help guys? Much appreciated and I'd buy you virtual beer! 😄
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
jltw7PSW2
Hi Kenny,
I am currently in a similar situation.
I know this post and comment are fairly old at this point, but i'm wondering if you ever found a soloution to this?
Best Regards
Jonas
Mathias_CompC
I recently replied to another thread that in the end didn't really need the answer I gave, but perhaps it could help you out.
Here
