iLogic Form Tooltip: Insert line break?
DRoam
Mentor Mentor
DRoam
Is there any way to insert a line break in an iLogic Form tooltip? Like in the message below:
I tried a couple Alt codes (Alt+010 for line feed, Alt+013 for carriage return) but neither works.
ccoomes
I know this is an old thread, but I have just managed to add a second line to and iLogic ToolTip.  Not an ideal method, but it works...
This was done by finding the tool tip in the form .xml file (not the State.xml file), and pressing return to start a new line.
Example if your form is called Test Form, look for the Test Form.xml in the iLogic UI Folder.  Not sure of the location as it will vary if you are using vault or not.
The image attached shows the difference in the XML file, and the difference in the form.
DRoam
That’s awesome! Good find, @ccoomes, thanks for sharing it here.
@MjDeck, can support for this be added natively in the iLogic Form editor UI?
MjDeck
Hi @DRoam , yes we could add that. I can see it would help a lot for creating readable tooltips with a significant amount of detail.
Mike Deck
Software Developer
Autodesk, Inc.
