iLogic form tooltip crops last word
As the title says, if I enter a tooltip, the last word does not show up.
Inventor 2019.3
Not sure how long this has been happening.
Examples
"Do not add custom values" displays "Do not add custom"
"Do not add custom values ." displays "Do not add custom"
"Do not add custom values a" displays "Do not add custom"
"Do not add custom values ab" displays "Do not add custom values"
so there needs to be at least 2 "throwaway" characters after the tooltip I want to display.
what gives?
Stay healthy, everybody!
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Please specify the Inventor version that is associated with mentioned issue.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
As mentioned in the original post - Inventor 2019.3
gcoombridge
I was about to make a post about this and saw yours. I'm just adding an extra word on the end of each tooltip to make them appear... Pretty silly problem. Sample file attached.
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
gcoombridge
Just bumping this - is it still an issue in 2022 and has it been understood by Autodesk?
