iLogic form - Show on place component
DWhiteley
Advisor Advisor
DWhiteley
Show on Place Component
If I set this to true, then when I "place iLogic component", I don't get the form displayed or the parameter table or the model preview.
 Any ideas why?
If set True, displays the form when placing this model as a component in an assembly. This setting affects Place Component and Place iLogic Component. If the template file has a form, this setting also affects Create In-Place Component.
MjDeck
Can you post a sample part that shows this problem?
Mike Deck
Software Developer
Autodesk, Inc.
