iLogic Form/Rule to copy/replace/reuse components
J.Oye
J.Oye
I have been searching high and low for If there's away to have a form be utilized that would do the same thing as the design assistant when closed out of files where you can select whether you want to reuse, copy or replace components.  I don't want to have to enter prefix or suffix per copied component just be able to rename them entirely.  design assistant is a great tool I just want the user the ability to do it in the assembly they have actively open.  Specifying folder location for copied components would be great as well.
Thanks in advance!!!!
j.brodersen
Hi J.Oye
I'm new to vba/Ilogic programming but I think that a slightly modded version of save-copy-and-replace-with-i-logic
is what you are looking for!?
I would guess that following code in an assembly would do the job
Sub Main()
Dim dialog As New System.Windows.Forms.FolderBrowserDialog()
If dialog.ShowDialog()= System.Windows.Forms.DialogResult.OK Then
	NewPath = dialog.SelectedPath
	MsgBox(NewPath)
 Dim Path As String = NewPath
 Dim FileChange As Boolean = False
 InvDoc = ThisDoc.Document
 Dim refDocs As DocumentsEnumerator = InvDoc.AllReferencedDocuments
 Dim refDoc As Document
 For Each refDoc in refDocs
 'MessageBox.show(refDoc.DisplayName)
 'input box to enter new file name
 NewFileName = InputBox("What is the new file name for " & refDoc.DisplayName & "?", "New File Name", refDoc.DisplayName)
 'NewFileName = InputBox("What is the new file name for " & refDoc.DisplayName & "?", "New File Name", iProperties.Value(refDoc.DisplayName, "Project", "Part Number"))
     'if the new file name is blank then use the same name
     If NewFileName = "" Then
         NewFileName = refDoc.DisplayName
     'if the user also types in the extesion then remove the extension.
     If NewFileName.EndsWith(".ipt") = True Then
         NewFileName = NewFileName.substring(0,NewFileName.length-4)
         'MessageBox.show(NewFileName)
     'if there is an change in the name then do the following.
     If refDoc.DisplayName <> NewFileName & ".ipt" Then
         'check to see the file already exist. if it does then replace.
         If System.IO.File.Exists(Path & NewFileName & ".ipt") Then
             Component.Replace(refDoc.DisplayName, Path & NewFileName & ".ipt", True)
         Else
             Dim oldName As String = refDoc.DisplayName
             'if it does not exist then recreate the file
             refDoc.saveas(Path & NewFileName & ".ipt",False)
             Call UpdateDrawing(Path, oldName, NewFileName)
         FileChange = True
 Next
 If FileChange = True Then
     NewAssemblyName = InputBox("What is the new file name for the assembly?", "New Assembly File Name", iProperties.Value("Project", "Part Number"))
     If NewAssemblyName <> "" Then
         Dim oldName As String = ThisDoc.FileName(True) 'include extension
         ThisDoc.Document.SaveAs(Path & NewAssemblyName & ".iam" , False)
         Call UpdateDrawing(Path, oldName, NewAssemblyName)
 iLogicVb.UpdateWhenDone = True
 End Sub
 Private Sub UpdateDrawing (ByVal Path As String, ByVal oldName As String, ByVal newName As String)
     Dim oDestinationDoc As DrawingDocument
     Dim strFileExtension As String = oldName.substring(oldName.Length-4,4)
     oldName = oldName.substring(0,oldName.Length-4)
     Dim sFileName As String = Path & oldName & ".idw"
     Try
         If System.IO.File.Exists(sFileName) Then
             oDestinationDoc = ThisApplication.Documents.Open(sFileName)
             oDestinationDoc.saveas(Path & newName & ".idw",False)
             Dim oDocDescriptor As DocumentDescriptor
             oDocDescriptor = oDestinationDoc.ReferencedDocumentDescriptors.Item(1)
             Dim oFileDescriptor As FileDescriptor
             oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
             oFileDescriptor.ReplaceReference(Path & newName & strFileExtension)
             oDestinationDoc.Update()
             oDestinationDoc.Close
     Catch
         MessageBox.Show("error")
     End Try
 End Sub
