iLogic for hide/show every possible object
b_kurt_ch
b_kurt_ch
Hello
Since Autodesk doesn't natively provide this functionality, I'd like to implement my own tool/iLogic to toggle the visibility of selected objects throughout the software.
All features for which Inventor natively provides visibility functionality must be grouped into one code to manage them via a shortcut.
Regardless of the user's selection (and multi selection), the code should toggle the visibility of these objects:
.ipt
– Sketches, 3D sketches
– Work features (axes, planes, points, etc.)
– Origin features
.iam
– Components
– Subcomponents
– All features from the .ipt
.idw
– Components
– Individual lines/splines
- All features from .ipt
Are there already existing tool I did not found?
Or any hint how to start this more complex project?
Thanks in advance.
b_kurt_ch
Oh wow, this was impressive.
More as a joke, I asked ChatGPT the same.
Following cool, working code as an answer:
Sub Main()
' iLogic: Sichtbarkeit umschalten je nach Dokumenttyp und Auswahl
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oSelSet As SelectSet = oDoc.SelectSet
If oSelSet.Count = 0 Then
    MsgBox("Bitte mindestens ein Objekt auswählen.", vbExclamation)
    Return
Select Case oDoc.DocumentType
    ' PART-Dokument (.ipt)
    Case DocumentTypeEnum.kPartDocumentObject
        For Each oObj In oSelSet
            Call ToggleVisibility(oObj)
        Next
    ' ASSEMBLY-Dokument (.iam)
    Case DocumentTypeEnum.kAssemblyDocumentObject
        Next
    ' DRAWING-Dokument (.idw)
    Case DocumentTypeEnum.kDrawingDocumentObject
        Next
    Case Else
        MsgBox("Dokumenttyp wird nicht unterstützt.", vbExclamation)
End Select
End Sub
' Hilfsfunktion: Sichtbarkeit umschalten
Sub ToggleVisibility(oObj As Object)
    Try
        ' Falls das Objekt die Property "Visible" hat
        Dim t As Type = oObj.GetType()
        Dim p = t.GetProperty("Visible")
        If Not p Is Nothing Then
            Dim current As Boolean = CBool(p.GetValue(oObj, Nothing))
            p.SetValue(oObj, Not current, Nothing)
            Exit Sub
        ' Spezielle Fälle behandeln:
        If TypeOf oObj Is ComponentOccurrence Then
            oObj.Visible = Not oObj.Visible
        ElseIf TypeOf oObj Is Sketch Then
        ElseIf TypeOf oObj Is WorkAxis Then
        ElseIf TypeOf oObj Is WorkPlane Then
        ElseIf TypeOf oObj Is WorkPoint Then
        ElseIf TypeOf oObj Is DrawingCurveSegment Then
		ElseIf TypeOf oObj Is DrawingCurve Then
            Dim oCurve As DrawingCurve = oObj
            Dim oOcc As ComponentOccurrence = oCurve.ModelGeometry.ContainingOccurrence
            If Not oOcc Is Nothing Then
                Dim oView As DrawingView = oCurve.Parent
                oView.SetVisibility(oOcc, Not oView.GetVisibility(oOcc))
        Else
            ' Optional: Debug-Ausgabe für nicht unterstützte Typen
            ' MsgBox("Kein Sichtbarkeits-Flag für: " & oObj.ToString)
    Catch ex As Exception
        MsgBox("Fehler bei: " & oObj.ToString & vbCrLf & ex.Message)
    End Try
End Sub
Components of a drawing view won't work.
AS well as sketches/features of components of an assembly. But as a start, this is a really cool and smart code.
Any idea how to improve?
b_kurt_ch
Here an updated version. Works fine except the components in drawing view.
Sub Main()
    MsgBox("Selektiere zuerst etwas (Bauteil, Ebene, Skizze...)", vbExclamation)
    Return
' Ursprüngliche Auswahl sichern
Dim savedSelection As New List(Of Object)
    savedSelection.Add(oObj)
Next
Next
' Auswahl wiederherstellen
oSelSet.Clear()
For Each oObj In savedSelection
    Try
        oSelSet.Select(oObj)
    Catch
        ' Falls Objekt nicht mehr auswählbar ist (z.B. ausgeblendet)
    End Try
Next
End Sub
    Try
            Exit Sub
        ' Skizzen im Part
        ElseIf TypeOf oObj Is PlanarSketch Then
        ElseIf TypeOf oObj Is Sketch3D Then
        ' Skizzen in der Baugruppe (Proxy)
        ElseIf TypeOf oObj Is PlanarSketchProxy Then
		    Dim oProxy As PlanarSketchProxy = oObj
		    Dim oNative As PlanarSketch = oProxy.NativeObject
		    oNative.Visible = Not oNative.Visible
		    ' Occurrence im Assembly holen und sicherstellen, dass Skizzen angezeigt werden
		    Dim occ As ComponentOccurrence = oProxy.ContainingOccurrence
		    If Not occ Is Nothing Then
		        If oNative.Visible Then
		            occ.Visible = True ' Stellt sicher, dass Komponente sichtbar ist
		            occ.Parent.ShowComponentSketches = True ' Skizzenanzeige aktivieren
        ElseIf TypeOf oObj Is Sketch3DProxy Then
		    Dim oProxy As Sketch3DProxy = oObj
		    Dim oNative As Sketch3D = oProxy.NativeObject
		            occ.Visible = True
		' Arbeitsebenen
		ElseIf TypeOf oObj Is WorkPlaneProxy Then
		    Dim oProxy As WorkPlaneProxy = oObj
		    Dim oNative As WorkPlane = oProxy.NativeObject
		    ' Sicherstellen, dass Arbeitsebenen in der Baugruppe angezeigt werden
		    If Not occ Is Nothing AndAlso oNative.Visible Then
		        occ.Visible = True
		        occ.Parent.ShowComponentWorkPlanes = True
		' Arbeitsachsen
		ElseIf TypeOf oObj Is WorkAxisProxy Then
		    Dim oProxy As WorkAxisProxy = oObj
		    Dim oNative As WorkAxis = oProxy.NativeObject
		        occ.Visible = True
		        occ.Parent.ShowComponentWorkAxes = True
		' Arbeitspunkte
		ElseIf TypeOf oObj Is WorkPointProxy Then
		    Dim oProxy As WorkPointProxy = oObj
		    Dim oNative As WorkPoint = oProxy.NativeObject
		        occ.Visible = True
		        occ.Parent.ShowComponentWorkPoints = True
		' Komponentenmuster Rund
		ElseIf TypeOf oObj Is CircularOccurrencePattern Then
		' Komponentenmuster Rechteckig
		ElseIf TypeOf oObj Is RectangularOccurrencePattern Then
		' Flächenkörper
		ElseIf TypeOf oObj Is SurfaceBody Then
        ' Zeichnungselemente
        Else
             'Optional: Debug-Ausgabe für unbekannte Typen
			 MsgBox("Kein Sichtbarkeits-Flag für: " & TypeName(oObj) & vbCrLf & "Voller Name: " & oObj.GetType().FullName)
        MsgBox("Fehler bei: " & oObj.ToString & vbCrLf & TypeName(oObj) & vbCrLf & ex.Message)
    End Try
End Sub
b_kurt_ch
Any advice how to solve the remaining problem with components in drawing views?
