ilogic for changing part color to drawing edges colors
glotz_99
Message 1 of 1
glotz_99
Can someone please help me with some ilogic code? I found some on here but none seem to work, but I'm trying to get all the part edges to match the part color so when it is turned into an dwg file, any piping or parts that are "red" for example will be the color "red" and on a layer called "red" in autocad. So far when I run this only certain parts will actually do this and the rest of the parts stay black and white. Can anyone help me?  I'm using Inventor Pro 2021.
Public Sub ChangeLayerOfOccurrenceCurves()
   ' Get the active drawing document.
   Dim drawDoc As DrawingDocument
   Set drawDoc = ThisApplication.ActiveDocument
   ' Have the user select a drawing view.
   Dim drawView As DrawingView
   Set drawView = ThisApplication.CommandManager.Pick( _
                  kDrawingViewFilter, "Select a drawing view.")
   Dim docDesc As DocumentDescriptor
   Set docDesc = drawView.ReferencedDocumentDescriptor
   ' Verify that the selected drawing view is of an assembly.
   If docDesc.ReferencedDocumentType <> kAssemblyDocumentObject Then
      MsgBox "The selected view must be of an assembly."
      Exit Sub
   ' Get the component definition for the assembly.
   Dim asmDef As AssemblyComponentDefinition
   Set asmDef = docDesc.ReferencedDocument.ComponentDefinition
   ' Process the occurrences, wrapping it in a transaction so the
   ' entire process can be undone with a single undo operation.
   Dim trans As Transaction
   Set trans = ThisApplication.TransactionManager.StartTransaction( _
                               drawDoc, "Change drawing view color")
   ' Call the recursive function that does all the work.
   Call ProcessAssemblyColor(drawView, asmDef.Occurrences)
   trans.End
End Sub
Private Sub ProcessAssemblyColor(drawView As DrawingView, _
                                 Occurrences As ComponentOccurrences)
   ' Iterate through the current collection of occurrences.
   Dim occ As ComponentOccurrence
   For Each occ In Occurrences
      ' Check to see if this occurrence is a part or assembly.
      If occ.DefinitionDocumentType = kPartDocumentObject Then
         ' ** It's a part so process the color.
         ' Get the render style of the occurrence.
         Dim color As RenderStyle
         Dim sourceType As StyleSourceTypeEnum
         Set color = occ.GetRenderStyle(sourceType)
         ' Get the TransientsObjects object to use later.
         Dim transObjs As TransientObjects
         Set transObjs = ThisApplication.TransientObjects
         ' Verify that a layer exists for this color.
         Dim layers As LayersEnumerator
         Set layers = drawView.Parent.Parent.StylesManager.layers
         Set drawDoc = drawView.Parent.Parent
         On Error Resume Next
         Dim colorLayer As Layer
         Set colorLayer = layers.Item(color.Name)
         If Err.Number <> 0 Then
            On Error GoTo 0
            ' Get the diffuse color for the render style.
            Dim red As Byte
            Dim green As Byte
            Dim blue As Byte
            ' Create a color object that is the diffuse color.
            Call color.GetDiffuseColor(red, green, blue)
            Dim newColor As color
            Set newColor = transObjs.CreateColor(red, green, blue)
            ' Copy an arbitrary layer giving it the name
            ' of the render style.
            Set colorLayer = layers.Item(1).Copy(color.Name)
            ' Set the attributes of the layer to use the color,
            ' have a solid line type, and a specific width.
            colorLayer.color = newColor
            colorLayer.LineType = kContinuousLineType
            colorLayer.LineWeight = 0.02
         On Error GoTo 0
         ' Get all of the curves associated with this occurrence.
         Dim drawcurves As DrawingCurvesEnumerator
         Set drawcurves = drawView.DrawingCurves(occ)
         If Err.Number = 0 Then
            On Error GoTo 0
            ' Create an empty collection.
            Dim objColl As ObjectCollection
            Set objColl = transObjs.CreateObjectCollection()
            ' Add the curve segments to the collection.
            Dim drawCurve As DrawingCurve
            For Each drawCurve In drawcurves
               Dim segment As DrawingCurveSegment
               For Each segment In drawCurve.Segments
                  objColl.Add segment
               Next
            Next
            ' Change the layer of all of the segments.
            Call drawView.Parent.ChangeLayer(objColl, colorLayer)
         On Error GoTo 0
      Else
         ' It's an assembly so process its contents.
         Call ProcessAssemblyColor(drawView, occ.SubOccurrences)
   Next
End Sub
Replies (0)
