iLogic find welding symbols with leaders
Guido.LangeTuchscherer
Hi there,
we are using welding symbols similar to leader notes, see image.
Thanks for any Help.
Dim dDoc As DrawingDocument
dDoc = ThisDoc.Document
Dim dSheet As Sheet
dSheet = dDoc.ActiveSheet
	'Prüfung ob schon gespeichert wurde
	If System.IO.File.Exists(dDoc.FullFileName) Then
		'Dateiname auslesen
		Dim dFI As New System.IO.FileInfo(dDoc.FullFileName)
		'Prüfung ob datei bearbeitet werden darf und geändert wurde
		If dFI.IsReadOnly = False And ThisDoc.Document.Dirty = True Then
			If dDoc.DocumentType = kDrawingDocumentObject Then 'ThisDoc.Document.DocumentType = kDrawingDocumentObject Then
'				MsgBox("Zeichnung") 'Funktioniert
	' Iterate over all Weldingsymbol in the drawing
	Dim oTG As TransientObjects
	    oTG = ThisApplication.TransientObjects
	Dim dLeaderCollection As ObjectCollection
	    dLeaderCollection = oTG.CreateObjectCollection
	Dim dLeaderNote As LeaderNote
	For Each dLeaderNote In dSheet.DrawingNotes.LeaderNotes
		 	 dLeaderCollection.Add(dLeaderNote)
			 MsgBox(dLeaderNote.Text & " | " & dLeaderNote.Type.ToString & " | " & dLeaderNote.DimensionStyle.Type.ToString)
	Next
chandra.shekar.g
Autodesk Support
Autodesk Support
@Guido.LangeTuchscherer ,
Unfortunately, weld symbols are not supported by Inventor API (iLogic). Please log a wish list at the idea station using the below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thanks @chandra.shekar.g,
but what does this mean then:
Inventor 2021 Drawings
The ThisDrawing object now implements the new IManagedDrawing interface (which inherits from the older ICadDrawing interface). ThisDrawing now supports managed drawing objects: dimensions and annotations.
Source:
https://help.autodesk.com/view/INVNTOR/2022/DEU/?guid=d7415521-ae14-4fab-ab1b-85086d6c0bc9
I thought welding symbols would be some kind of annotations?
Regards
chandra.shekar.g
Autodesk Support
Autodesk Support
@Guido.LangeTuchscherer,
Introduction of API related to weld symbol is already noticed by many users. It has been reported as a wish list at idea station.
Weld symbols exposed in the API in assemblies - autodesk
Engineering team is observing all wish list. If more number of users are observing, it may be considered in future release of Inventor.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Thanks @chandra.shekar.g I understand that,
What does this mean though?
"The ThisDrawing object now implements the new IManagedDrawing interface (which inherits from the older ICadDrawing interface). ThisDrawing now supports managed drawing objects: dimensions and annotations."
See Links above.
Thanks for your Answer and the Links.
