iLogic find and change similar iPart memeber's
Log0ut
Log0ut
I have ipart components in my assembly: iPart_member1:1; iPart_member1:2; iPart_member1:3 ...
Now i want to find and change all iPart_member1's to iPart_member2
Simple code be like that:
iPart.ChangeRow("iPart_member1:1", "iPart_member2.ipt")
iPart.ChangeRow("iPart_member1:2", "iPart_member2.ipt")
iPart.ChangeRow("iPart_member1:3", "iPart_member2.ipt")
Is there a way to do it automatically?
johnsonshiue
Hi! I am sorry I don't get what you meant by "automatically". The iLogic rule should help you execute the commands instead of manually changing the members.
Many thanks!
Software Test Engineer
Log0ut
I mean that code reads all 'iPart_member1's in my assembly and change them to iPart_member2.ipt
I found that i cant do it like that:
Component.Replace("iPart_member1:1", Lpath & "iPart_member2.ipt", True)
 and this is allmost solution for my problem..
But if somehow "iPart_member1:1" gonna be deleted, then this code stops working. Although there are still "iPart_member1:2", "iPart_member1:3"...
How i can find "iPart_member1:(?)"
JhoelForshav
Hi @Log0ut
If i understand correctly you want to replace the components if their name contains "iPart_member1:"?
Then something like this should do the trick 🙂
For Each oOcc As ComponentOccurrence In ThisDoc.Document.ComponentDefinition.Occurrences
If oOcc.Name.Contains("iPart_member1:")
Component.Replace(oOcc.Name, Lpath & "iPart_member2.ipt", True)
Exit For
Next
