iLogic Extrude
iLogic Extrude
Cosmin_V
iLogic Extrude
Cosmin_V
I have an extrusion for cutting on a plan, which is moving.
And if I move it to much the extrusion will be "No Effect".
Is there a code which … If feature "Delete" =No Effect
                                              feature "Delete" = false
Many Thanks!
Justin.B.
If you know the location where the cut starts leaving no change, the easiest thing to do would be to disable the feature when its position is beyond that value.
If yourPositionParameter >= 5 mm Then
	Feature.IsActive("yourFeature") = False
Else
	Feature.IsActive("yourFeature") = True
If that position is harder to anticipate, you can check the health status of your features and disable them when they're sick like this:
For Each oFeature As PartFeature In ThisDoc.Document.ComponentDefinition.Features
	If oFeature.Name = "yourFeature" Then
		If oFeature.HealthStatus = HealthStatusEnum.kDriverLostHealth Then
Next
I found more details and more health statuses here:
https://forums.autodesk.com/t5/inventor-forum/checking-constraint-health-in-ilogic/m-p/6396661/highl...
Hope that helps
