Ilogic exporting true false parameters
SpokenEarth
SpokenEarth
I have an ipt consisting true-false statements, how can i export these statement into iam
Thank you
Accepted solutions (3)
FINET_Laurent
I don't think you can ?
How I did is retrieve the parameter value using iLogic.
In the assembly you can create a rule and do :
If Parameter("Part.ipt", "Parameter") = True Then
	'do something here
Else If Parameter("Part.ipt", "Parameter") = False Then
	'do something here
 Hope this helps.
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
WCrihfield
You can try putting this iLogic rule in your main assembly which contains that part, then run it.  This will attempt to copy all Boolean type user parameters from that specifically named part to the active assembly.  It starts by getting the UserParameters object of the 'active' assembly.  Then, in order to get the UserParameters object of the target part, it starts looping through all referenced documents for the one by that name.  Once found, it gets its UserParameters object, so we can start working with both sets.  If it doesn't find that part, it lets you know, then exits the rule.  When both parameter groups are retrieved, it starts looping through the part's user parameters, checking their units type.  If 'Boolean', it then tries to set the value of the same parameter within the assembly, and if that fails, it tries to create a new user parameter within the assembly with the same name and value.  If both of those methods fail, it lets you know, then continues to any others or finishes.
Here's the code:
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
	Exit Sub
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAUParams As UserParameters = oADoc.ComponentDefinition.Parameters.UserParameters
Dim oPUParams As UserParameters
Dim oFound As Boolean = False
For Each oRefDoc As Document In oADoc.AllReferencedDocuments
	If System.IO.Path.GetFileName(oRefDoc.FullFileName) = "TORISPHERICAL HEAD.ipt" Then
		Dim oPDoc As PartDocument = oRefDoc
		oPUParams = oPDoc.ComponentDefinition.Parameters.UserParameters
		oFound = True
		Exit For
Next
If oFound = False Then
	MsgBox("Couldn't find part named 'TORISPHERICAL HEAD.ipt' in the active assembly. Exiting.", vbOKOnly + vbExclamation, "")
	Exit Sub
For Each oUParam As UserParameter In oPUParams
	If oUParam.Units = "Boolean" Then
		Try
			oAUParams.Item(oUParam.Name).Value = oUParam.Value
		Catch
			oAUParams.AddByValue(oUParam.Name, oUParam.Value, UnitsTypeEnum.kBooleanUnits)
		Catch
			MsgBox("Couldn't copy parameter named " & oUParam.Name & " from part to assembly.", , "")
		End Try
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
SpokenEarth
It works!!! 🙂
Thank you so much
SpokenEarth
It seems like I can now import true-false statements into iam but i'm not allow to edit them......im I doing something wrong here?
WCrihfield
In which way can't you edit them?  Can you explain further?
Are you trying to change the value of the parameter within the main assembly document, then expecting it to also change the value of the same parameter within the part that it was copied from?  If so, you will need to 'link' the two parameters, not just copy them.  When they have just been copied from one document to another, the parameters are independent of each other.  If you do need to link the parameters, you would add them to the assembly in a slightly different way.  Here are is one link (of many) to a post where linking parameters between documents is discussed.
To add parameters in to current document from another
Basically, you access the parameters of both documents within the code.  Make sure the parameters that are to be linked are set as exposed/export within the parameters dialog of the source document.  Add the source parameters to an ObjectCollection, then add a derived parameter table to the target document, with that collection as the parameters to include in it.
Wesley Crihfield
SpokenEarth
My mistake....it works like a charm!!
Thank you so much again
