iLogic Exporting all as .DXF issue
Hello all,
I have an issue with a iLogic code from: https://clintbrown.co.uk/2021/01/13/ilogic-export-flat-patterns-of-ipart-members-to-dxf/
The iLogic runs perfectly, and saves all instances as .DXF files separately. However, the parts are not saved with the correct geometries. I am not skilled enough to edit this code myself, so I was wondering if someone could help.
Here is the problem:
Notice all pats have the number "1", but in inventor the parts are clearly 1,2,3,4:
bhavik4244
@Anonymous
Can you please attach the iPart?
Bhavik Suthar
Yes, I have included the .ipt file to this reply. I should make that a habit thankyou!
bhavik4244
@Anonymous
I have checked the part and it seems like the emboss feature is causing the issue. I would recommend just delete/ Suppress that feature and run the rule. It will give the correct dxf.
I can understand your concern to give the number as emboss to recognize the dxf, however, you can able to detect that with the file name of dxf. I have given the rule in such a way that it will save with the member name so one can easily identify.
Bhavik Suthar
Unfortunately, outright deleting the emboss feature isn't an option. I need each panel to have a unique number for etching on a laser cutter. I tried cut extruding them, however they end up on the same layer, which also causes problems. Any suggestions? Maybe there is another feature I can use that still maintains separate layers, and the number exports differently, or would the solution require modification to the iLogic?
bhavik4244
@Anonymous
Yes, modification needs to be done on iLogic rule.
https://clintbrown.co.uk/2020/09/19/ilogic-setting-extra-layers-in-dxf-exports/
In this post, you may find to play with dxf layers. You may modify the code accordingly and achieve the result. I hope this could solve your issue.
Bhavik Suthar
