ILogic Export IGS and Images Code? [Help]
Astrolabe2015
Message 1 of 1
Astrolabe2015
Hello everyone,
I've been looking for a code to export images (.png, .tiff and .jpg) and .igs at the same time. So i tried to contact the Autodesk support so that someone could try to help. After I exposed my vision of what this code could've done I've got a reply with a code that was later told to be a sample template and that the support couldnt help me with this since he/she had not enough knowledge of iLogic to help me, the code goes as follows:
'Export to JPG
Dim oPart = ThisDoc.Document
oPart.SaveAs("c:\temp\export.jpg", True)
Dim oIges = ThisApplication.ApplicationAddIns.ItemById("{90AF7F44-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext  = ThisApplication.TransientObjects.CreateTranslationContext()
Dim oIgesMap As NameValueMap
oIgesMap = ThisApplication.TransientObjects.CreateNameValueMap()
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Trace.TraceInformation("Iges: create data medium")
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium()
oData.FileName = "C:\temp\export.igs"
oIgesMap.Add("GeometryType", 1)
'Export to IGS
oIges.SaveCopyAs(oPart, oContext, oIgesMap, oData)
This doesnt follow my requirements since I need that:
-  The images and igs stay with the same file name as member name/part name of the source .ipt.
-  The images and igs stay in the same folder as the source .ipt.
-  And the ability to set a specific resolution to the exported images.
Any help? I've tried changing the code, and generating my own and still I've only met errors.
Thank you
Replies (0)
