iLogic : Export idw part data to text file
Message 1 of 11
We have an idw package we use for Quality control. This idw has more than one sheet. Each sheet has a part placed on the sheet with dims.( DWF attached). Next we open DA inside of the file and run a report. (exported txt attached). I am trying to use ilogic the make the same report with a iLogic browser button pick. I have 2 codes (code examples on attached jpg) that i need to make into 1, or what ever works. Any help would be great.
Having trouble attaching the DWF so it is not attached
1st code
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSubDoc As Inventor.Document
Dim oPropSets As PropertySets
Dim oPropSet As PropertySet
Dim oPartNumiProp As Inventor.Property
For Each oSubDoc In oDoc.AllReferencedDocuments
    If oSubDoc.documenttype = kpartdocumentobject Then
    oPropSets = oSubDoc.PropertySets
    oPropSet = oPropSets.Item("Inventor User Defined Properties")
    oPartNumiProp = oPropSet.Item("PCMK")
        sMsg=sMsg & oSubDoc.FullFileName & vbLf
Next
    MessageBox.Show(sMsg, "PCMK")
 2nd code
fileheader = "QAF Parts for Planning "
fileheader1 = ThisDoc.PathAndFileName(True) 'first line header of txt file
description = "Components to use for Nesting" 'use this variable in the body of the txt
delimiter = "," 'character to separate the names and values on each line
oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt")
oWrite.WriteLine(fileheader) 'include the fileheader on the first line
oWrite.WriteLine(fileheader1) 'include the fileheader on the first line
oWrite.WriteLine(description) 'include the description on the second line
oWrite.WriteLine(Now()) 'include the current date and time on the third line
oWrite.WriteLine() 'blank line
oWrite.Close()
'option to view report
go = MessageBox.Show("Would you like to view the txt file?", "QAF Nesting Report", MessageBoxButtons.YesNo)
If go = 6 Then ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt")
Replies (10)
Message 2 of 11
Just realized that my 1st text file looks bad.
Message 3 of 11
adam.nagy
Autodesk Support
Autodesk Support
Hi Andrew,
Where do you run into problems with combining the two code?
I think this is what you are trying to do:
        sMsg=sMsg & oSubDoc.FullFileName & " - " & oPartNumiProp.Value & vbLf
Next
oWrite.Write(sMsg)
oWrite.Close()
Cheers,
Adam Nagy
Autodesk Platform Services
Message 4 of 11
Thanks Adam
That gets them together. I will work on it looking like the ilogic.txt file above.
Message 5 of 11
Help
I can't get the code to sort with columns like image above.
Message 6 of 11
admaiora
Hi Adam,
i have this error using your code,  what do you think?
Thank you Adam! Merry Christmas!
Error in rule: Rule2, in document: Test.ipt
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.DrawingDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D467-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: Interfaccia non supportata. (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
The code
Next
oWrite.Write(sMsg)
oWrite.Close()
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 7 of 11
adam.nagy
Autodesk Support
Autodesk Support
Hi Mat,
First I thought it was similar to this issue:
http://adndevblog.typepad.com/manufacturing/2014/04/disp_e_membernotfound-error-from-ilogic.html
Then realized it's even simpler: "Error in rule: Rule2, in document: Test.ipt"
You are using this rule inside a part document but it expects a drawing document.
In that case you don't have to iterate through the referenced documents of the part document, but instead read the part document's properties directly. Just to show how things get modified I just comment out what you don't need:
'Dim oDoc As DrawingDocument
'oDoc = ThisApplication.ActiveDocument
oSubDoc = ThisApplication.ActiveDocument 'added
'For Each oSubDoc In oDoc.AllReferencedDocuments
'    If oSubDoc.documenttype = kpartdocumentobject Then
'    End If
'Next
Merry Christmas and Happy New Year! 🙂
Cheers,
Adam Nagy
Message 8 of 11
admaiora
Thank you for your interesting Adam!
Actually even in the drawing file i receive an error
Error in rule: Rule8, in document: text ilogic.idw
Errore non specificato. (Exception from HRESULT: 0x80004005 (E_FAIL))
using this
Next
oWrite.Write(sMsg)
oWrite.Close()
More info
System.Runtime.InteropServices.COMException (0x80004005): Errore non specificato. (Exception from HRESULT: 0x80004005 (E_FAIL))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.PropertySet.get_Item(Object Index)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Thank you,  your help makes the difference. Thanks
Admaiora
Message 9 of 11
adam.nagy
Autodesk Support
Autodesk Support
Do all the part documents referenced by the drawing file have a User Property called "PCMK"?
Because that's what that code is trying to read.
Is that what you need or what exactly are you trying to automate?
Adam Nagy
Message 10 of 11
admaiora
It was as you said Adam.
Thank you again for solving my problem.
I wish you an happy new year!
Admaiora
Message 11 of 11
hi!
It's possible for the fileheader to insert a existing text file
fileheader = I:\TEST\HEADER.TXT
Thanks for your help 🙂
