iLogic: Export All Flat Patterns To One DXF Edit Request
erasarnova
erasarnova
Hi all ,
I'm using this iLogic code but i need some changes that i couldn't do.
1-) I need thickness information of part instead of scale information.
2-) I need bending lines as yellow colour
3-) I need all same thickness parts should be in seperate rows if it is possible.
4-) I need to change space(10mm) as default between two parts to 100mm.
I would appreciate if somebody helps.
Sub Main
	'iLogic Code by Jhoel Forshav - originally posted at https://clintbrown.co.uk/ilogic-export-all-flat-patterns-to-one-dxf
	'Check that the active document is an assembly file
	If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
		MessageBox.Show("This rule can only run from an Assembly file", "DXF-creator", MessageBoxButtons.OK, MessageBoxIcon.Error)
		Exit Sub
	'Dim the active document as AssemblyDocument
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	'Make sure the assembly is saved
	If oDoc.FullFileName = ""
		MessageBox.Show("Please save the Assembly before running this rule.", "DXF-creator", MessageBoxButtons.OK, MessageBoxIcon.Information)
		Exit Sub
	'Get the assembly filename without extension
	Dim oAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
	'Get the assembly filepath
	Dim oPath As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName)
	'Get the parts only BOM.
	Dim oBOM As BOM = oDoc.ComponentDefinition.BOM
	'Make sure Parts Only is activated
	oBOM.PartsOnlyViewEnabled = True
	'Parts only will be last BomView (difficult to get by name since it's different depending on your language)
	Dim oBOMview As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count)
	'Set a reference to the TransientGeometry object
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	'oX and oY will be used to create points for view placement
	Dim oX As Double = 0
	Dim oY As Double = 0
	'Create the Baseview options to place flatpattern-views
	Dim oBaseViewOptions As NameValueMap
	oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oBaseViewOptions.Add("SheetMetalFoldedModel", False)
	'Set a variable for the drawing document
	Dim oDrawing As DrawingDocument
	'Create a String to return a message if any SM-parts are not saved
	Dim unsavedSmParts As String = ""
	Dim i As Integer = 1
	Dim oInfo As String = ""
	'Traverse Parts Only BOM
	For Each oRow As BOMRow In oBOMview.BOMRows
		Try
			'Get the component definition for the part
			Dim oDef As ComponentDefinition = oRow.ComponentDefinitions(1)
			'Check if the part is SheetMetal
			If TypeOf (oDef) Is SheetMetalComponentDefinition
				'Set a reference to the partdocument
				Dim smPartDoc As PartDocument = oDef.Document
				'Check if the part is saved
				If smPartDoc.FullFileName = "" Then
					If unsavedSmParts = "" Then unsavedSmParts = "The fallowing SM-documents were not saved and therefore " & _
					"no drawingviews were created:" & vbCrLf
					unsavedSmParts = unsavedSmParts & vbCrLf & oDef.Document.DisplayName
					Continue For
				'Create flatpattern if it doesn't already exist
				If Not oDef.HasFlatPattern
					oDef.Unfold()
					oDef.FlatPattern.ExitEdit()
				'Create the drawing if it doesn't already exist
				If oDrawing Is Nothing
					oDrawing = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, _
					, False)
					'Set the drawings length units to the same as the assemblys length units
					oDrawing.UnitsOfMeasure.LengthUnits = oDoc.UnitsOfMeasure.LengthUnits
				'Set a reference to the drawing sheet
				Dim oSheet As Sheet = oDrawing.ActiveSheet
				'Create the flatpattern view
				Dim oView As DrawingView = oSheet.DrawingViews.AddBaseView(smPartDoc, oTG.CreatePoint2d(oX, oY), 1 _
				, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, _
				"FlatPattern", , oBaseViewOptions)
				oView.Name = smPartDoc.DisplayName
				oView.ShowLabel = True
				'Set the position with our oX and oY
				oView.Position = oTG.CreatePoint2d(oView.Position.X + oView.Width / 2, oView.Position.Y)
				'Move oX to place the next view to the right of this one
				oX = oView.Left + oView.Width + 1
				'Remove the bend lines of the view
				RemoveBendLines(oView, oDef.FlatPattern)'You could comment out this line to keep bend lines
				oInfo = oInfo & If (i = 1, "", vbCrLf) & i & ". " & smPartDoc.PropertySets.Item("Design Tracking Properties"). _
				Item("Part Number").Value
				i += 1
				'Close the part
				smPartDoc.Close(True)
		Catch Ex As Exception
			MsgBox(Ex.Message)
		End Try
	Next
	If oDrawing IsNot Nothing
		'Create the save location string for the DXF
		Dim oDXFName As String = oPath & "\" & oAsmName & "_FlatPatterns.dxf"
		'Save the DXF
		oINI = "" 'Specify your INI file location here (eg C:\TEMP\DXF Export.ini)
		If oINI = "" Then
			MessageBox.Show("You need to specify an INI file location in the code - Look for oINI and set the path", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
		SaveDXF(oDrawing, oDXFName, oINI)
		'Create the save location string for the information txt
		Dim oInfoName As String = oPath & "\" & oAsmName & "_FlatPatterns.txt"
		'Create the txt
		CreateTXT(oInfo, oInfoName)
	'Close the drawing
	oDrawing.Close
	'return information about any unsaved parts
	If unsavedSmParts <> "" Then _
	MessageBox.Show(unsavedSmParts, "Some parts were not saved", _
	'Update the assembly (could be dirty if any flatpatterns were created)
	oDoc.Update
End Sub
Sub SaveDXF(oDrawing As DrawingDocument, oFileName As String, oIniFile As String)
	'Set a reference to the DFX translator
	Dim DXFAddIn As TranslatorAddIn
	DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
	'Create translation context
	Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	'Create options for the translation
	Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	'Create a DataMedium object
	Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	'Set the options (which .ini-file to use)
	If DXFAddIn.HasSaveCopyAsOptions(oDrawing, oContext, oOptions) Then
		oOptions.Value("Export_Acad_IniFile") = oIniFile
	'Set the filename property of the DataMedium object
	oDataMedium.FileName = oFileName
	Try
		'Try to save the DXF
		DXFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium)
		MessageBox.Show("Dxf saved to: " & oFileName, "DXF SAVED", MessageBoxButtons.OK, MessageBoxIcon.Information)
	Catch
		MessageBox.Show("Couldn't save dxf!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
	End Try
End Sub
Sub RemoveBendLines(oView As DrawingView, oFlattPattern As FlatPattern)
	'Get all the bend edges from the FlatPattern
	Dim oBendEdgesUp As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge)
	Dim oBendEdgesDown As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge)
	For Each oEdge As Edge In oBendEdgesUp
		'Get the curves representing these edges in the drawing view
		For Each oCurve As DrawingCurve In oView.DrawingCurves(oEdge)
			For Each oSegment As DrawingCurveSegment In oCurve.Segments
				'Set visibility to false
				oSegment.Visible = False
			Next
		Next
	Next
	For Each oEdge As Edge In oBendEdgesDown
			Next
		Next
	Next
End Sub
Sub CreateTXT(oText As String, oFileName As String)
	Dim oTxtWriter As System.IO.StreamWriter = System.IO.File.CreateText(oFileName)
	oTxtWriter.WriteLine(oText)
	oTxtWriter.Close()
End Sub
erasarnova
up
erasarnova
up
