iLogic Excel Lookup Multiple Possible Finds?
mthomas
mthomas
I"m attempting to use iLogic to populate a parts iProperties based on an excel spreadsheet. In this case there are 4-columns (Height, Width, Thickness, and Part #).
Using the height & width from the model with the "FindRow" function I am able to determine the first instance in the spreadsheet with these values, however what do I do when there are multiple lines with the same height and width but the thicknesses vary?
Since I have the first row that matches the height and width is there some way to interate until the height or width changes?
Mike Thomas
Can you not use your thickness in the lookup ? That would determine the unique row :
i = GoExcel.FindRow("c:\temp\testbook.xls", "Sheet1", "Height", "=", 1800, "Width", "=", 500, "Thickness", "=", 20)
Tom
mthomas
Doh!... of course the lookup can do more than 2-columns
Thanks!
Mike Thomas
