iLogic [Event Trigger] API for [Run these rules when events occur] check box?
Josh_Hunt
Josh_Hunt
I have many rules inside my parts that need to be triggered by Events. I just now realized that [Run these rules when events occur] check box is an APPLICATION setting. The triggers below are FILE settings.
Is there an API to this checkbox?
Josh Hunt
chandra.shekar.g
Autodesk Support
Autodesk Support
@Josh_Hunt,
There is a way to add a rule to event trigger through VBA code. but, Inventor API does not support to check and uncheck check box for "Run these rules when events occur". Below articles would help to add a rule to event triggers.
http://beinginventive.typepad.com/being-inventive/2012/02/injecting-ilogic-code-and-ilogic-event-tri...
http://adndevblog.typepad.com/manufacturing/2015/01/add-external-ilogic-rule-to-event-trigger.html
https://forums.autodesk.com/t5/inventor-customization/adding-an-ilogic-rule-to-an-event-trigger-with...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
C-Hoppen
Maybe you are lokking for this property?
Regards
Chris
greggeorgi
That setting is not the same as the checkbox. The checkbox is an application/persistent setting that cannot be called by the API on purpose for security intentions. The API call for RulesOnEventsEnabled is an API only accessible, session dependent trigger. It will reset to true on restart always. (Note this applies to the newer event interface/handling)
greggeorgi
You could possibly modify the xml preference file manually, but Im pretty sure an inventor restart would be required to reload the settings
C:\Users\<USER>\AppData\Roaming\Autodesk\Inventor 2020\iLogicPreferences\iLogicOptions.xml
Josh_Hunt
@greggeorgi Thank you but %APPDATA%\Autodesk\Inventor 2020\iLogicPreferences\iLogicOptions.xml does not hold that setting. I think @chandra.shekar.g is correct, that checkbox is a manual user change only.
Josh Hunt
