iLogic error with folding sheet metal
SharkDesign
Mentor Mentor
SharkDesign
I am using the following code to automatically create a flat pattern when I save a sheet metal document.
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim State As SheetMetalComponentDefinition
State=oDoc.ComponentDefinition
If State.HasFlatPattern = False Then
State.Unfold
The problem comes when I insert this part into an assembly. When the sheet metal part has been edited and I save the assembly I get the following error:
Error in rule: unfold, in document: Part19.ipt
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
More Info tab:
System.InvalidCastException: Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Any ideas?
  Inventor Certified Professional
Curtis_Waguespack
Hi jameswillo,
Give this a try.
I hope this helps.
Curtis
'Loop through any and all referenced documents
For Each oDoc In ThisApplication.ActiveDocument.AllReferencedDocuments
	'look at only sheet metal parts
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		State = oDoc.ComponentDefinition
			'create flat pattern
			State.Unfold
			'flip back to folded model
			State.FlatPattern.ExitEdit
			'close the file
			oDoc.Close(True) 'True skips the save
Next
'update assembly
InventorVb.DocumentUpdate()
SharkDesign
I'm assuming you put this code in the assembly rather than the part?
Am I right in thinking that if my assembly is very large this will massively increase my save time if it's going through every sheet metal part?
adam.nagy
Autodesk Support
Autodesk Support
If the rule is triggered when the assembly is active then this is the part that will fail causing error "Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'" because it's an assembly document:
Instead, you should work with the document that the rule resides in:
oDoc = ThisDoc.Document
Cheers,
Adam Nagy
Autodesk Platform Services
SharkDesign
Ahhhh, that makes sense. Thanks, I'll try that.
