Ilogic - Error setting occurence Appearance ( color )
Curtis_Waguespack
Consultant Consultant
Curtis_Waguespack
Can anyone help me figure out why this doesn't work?  It's based off of the following API example:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2018/ENU/Inventor-API/files/Se...
I get an error with this line:
oOccurrence.Appearance = localAsset
Here's the full rule:
' Get the active document.  Assumes a part document is active.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oDoc.ComponentDefinition
oColor = Parameter("Color_List")
oRun = Parameter("Component_List")
Dim localAsset As Asset
Try
	localAsset = oDoc.Assets.Item(oColor)
Catch
	Dim assetLib As AssetLibrary
	assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
	Dim libAsset As Asset
	libAsset = assetLib.AppearanceAssets.Item(oColor)
	' Copy the asset locally.
	localAsset = libAsset.CopyTo(ThisApplication.ActiveDocument)
End Try
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	If oOccurrence.Name = oRun Then
		MessageBox.Show("Component Name: " & oOccurrence.Name _
		& vbLf & "Color: " & localAsset.DisplayName , "iLogic")
Next
And attached is an example file set, with the rule in place.
Thanks in advance!
Curtis
sajith_subramanian
Autodesk Support
Autodesk Support
Hi Curtis,
Just declaring the occurrence as its respective type, that is as a ComponentOccurence seems to make it work for me.
That is
For Each oOccurrence  As ComponentOccurrence  In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
Could you try it out and let me know if it works.
Sajith
Sajith Subramanian
Autodesk Developer Network
Curtis_Waguespack
Hi sajith.subramanian,
Thanks! That is what I was missing. Smiley Embarassed
Thanks again,
Curtis
