iLogic editor bug/crash (pop-up help issue?) Version 2022.2
llorden4
llorden4
I'm getting a repeatable crash when typing in the iLogic editor with this particular code and have captured the conditions & error report from this event.
I am attempting to enter a "Catch" option to troubleshoot some code I'm working on; trying to type in...
MsgBox("i: " & CStr(i))
It keeps crashing as soon as I press the letter "c" on the keyboard.  I've tried suppressing my rule to keep it from firing, but I suspect the issue with the handler for pop-up help within the editor.
Error message:
System.InvalidOperationException: Failed to compare two elements in the array. ---> System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.SZArrayHelper.get_Item[T](Int32 index)
at ActiproSoftware.Windows.Controls.SyntaxEditor.IntelliPrompt.Implementation.ArgumentCompletionItemSortComparer.#Vlb(IQualifiedName #hlb)
at ActiproSoftware.Windows.Controls.SyntaxEditor.IntelliPrompt.Implementation.ArgumentCompletionItemSortComparer.Compare(ICompletionItem x, ICompletionItem y)
at System.Collections.Generic.ArraySortHelper`1.DepthLimitedQuickSort(T[] keys, Int32 left, Int32 right, IComparer`1 comparer, Int32 depthLimit)
at System.Collections.Generic.ArraySortHelper`1.Sort(T[] keys, Int32 index, Int32 length, IComparer`1 comparer)
--- End of inner exception stack trace ---
at System.Array.Sort[T](T[] array, Int32 index, Int32 length, IComparer`1 comparer)
at System.Array.Sort[T](T[] array, IComparer`1 comparer)
at ActiproSoftware.Windows.Controls.SyntaxEditor.IntelliPrompt.Implementation.CompletionSession.SortItems(IComparer`1 comparer)
at ActiproSoftware.Windows.Controls.SyntaxEditor.IntelliPrompt.Implementation.CompletionSession.SortItems()
at ActiproSoftware.Text.Languages.DotNet.Implementation.DotNetCompletionProviderBase.OnSessionOpening(ICompletionSession session)
at ActiproSoftware.Text.Languages.VB.Implementation.VBCompletionProvider.RequestSession(IEditorView view, Boolean canCommitWithoutPopup, Boolean requireExactMatch)
at ActiproSoftware.Text.Languages.VB.Implementation.VBCompletionProvider.OnDocumentTextChanged(SyntaxEditor editor, EditorSnapshotChangedEventArgs e)
at ActiproSoftware.Text.Languages.VB.Implementation.VBCompletionProvider.#llb(SyntaxEditor #mlb, EditorSnapshotChangedEventArgs #rb)
at ActiproSoftware.Windows.Controls.SyntaxEditor.SyntaxEditor.OnDocumentTextChanged(EditorSnapshotChangedEventArgs e)
at ActiproSoftware.Windows.Controls.SyntaxEditor.SyntaxEditor.RaiseDocumentTextChangedEvent(EditorSnapshotChangedEventArgs e)
at ActiproSoftware.Windows.Controls.SyntaxEditor.SyntaxEditor.OnDocumentTextChanged(Object sender, TextSnapshotChangedEventArgs e)
at ActiproSoftware.Windows.Controls.SyntaxEditor.SyntaxEditor.<>c.<AttachToDocumentEvents>b__59_10(SyntaxEditor instance, Object source, TextSnapshotChangedEventArgs eventArgs)
at ActiproSoftware.Text.Implementation.TextDocumentBase.OnTextChanged(TextSnapshotChangedEventArgs e)
at ActiproSoftware.Text.Implementation.CodeDocument.OnTextChanged(TextSnapshotChangedEventArgs e)
at ActiproSoftware.Text.Implementation.TextDocumentBase.#iO(#2O #MC, Action`1 #e8b)
at #gN.#2O.Apply()
at ActiproSoftware.Windows.Controls.SyntaxEditor.Primitives.EditorView.ReplaceSelectedText(ITextChangeType type, String text, IEditorViewTextChangeOptions options)
at ActiproSoftware.Windows.Controls.SyntaxEditor.EditActions.TypingAction.Execute(IEditorView view)
at ActiproSoftware.Windows.Controls.SyntaxEditor.Primitives.EditorView.ExecuteEditAction(IEditAction action)
at ActiproSoftware.Windows.Controls.SyntaxEditor.Primitives.EditorView.PerformTyping(String text)
at ActiproSoftware.Windows.Controls.SyntaxEditor.Primitives.EditorView.ProcessTyping(TextCompositionEventArgs e)
at ActiproSoftware.Windows.Controls.SyntaxEditor.Primitives.EditorView.OnTextInput(TextCompositionEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.TextCompositionManager.PostProcessInput(Object sender, ProcessInputEventArgs e)
at System.Windows.Input.InputManager.RaiseProcessInputEventHandlers(ProcessInputEventHandler postProcessInput, ProcessInputEventArgs processInputEventArgs)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndKeyboardInputProvider.ProcessTextInputAction(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndKeyboardInputProvider.FilterMessage(IntPtr hwnd, WindowMessage message, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at iLogic.EditRuleRunner.RuleModifyAndEval(ILmiRule rule, Boolean allowRunAfterEdit, Boolean& cancelled)
Autodesk Inventor Certified Professional
BenoitLarocque000
I have similar problem with 2022.2.
Models that used to update correctly with 2022.1 now gives me errors when propagating values from parameters located in parent assembly to a sub assembly (a simple true false parameter propagation crashes). I also have problem when running an update rule in a sub assembly from the parent assembly????   Any idea?
llorden4
Nope, and when I get no response at all from the Inventor team it usually means they don't either.
BenoitLarocque000
I uninstalled the 2022.2 service pack and everything went back to normal.
llorden4
Still having this issue in 2023.4, it's repeatable for me.
When attempting to manually type in this line.
oTickPnts(i, 1) = oTG.CreatePoint2d(oCLPoints(i, 1).X + x, oCLPoints(i, 1).Y + y)
 I get an editor crash/exit when I reach the location of "+ x" or "+ y".  I have to create the line of text without those entries, save and exit, re-enter the editor and then paste in that text in order to complete the line without the crash.
[Here's a copy & paste of the error report.]
at #gN.#2O.Apply()
llorden4
I was able to get this issue logged as INVGEN-76164
