ilogic dxf sheet metal export issue
I have some some code as below that I use to export flat patterns of parts to dxf. Basically what the code does go through unsupressed parts iproperties and looks for a value called "ISM" in the iproperties - summery - keywords, if this value is present then it produces a dxf of the part.
95% of the time it works but occasionally I get the below error message. There seems to be no pattern to when it appears but more likely after one of the parts is unsupressed and before a save of the assembly. However, after not working 2 or 3 times it suddenly begins to work again.
Error in rule: DXF, in document: IMPELLER.iam
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
Does anyone know of a reason why the a code below may be vunerable to occasionally not working? (Using Inventor 2014)
Example of code used below:-
DXF_LOC = ThisDoc.Path & "\IMPELLER_DXF\"
part_no = 1
Dim oDoc As Document
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
Dim asmDef As AssemblyComponentDefinition
asmDef = asmDoc.ComponentDefinition
Dim oComp As Inventor.ComponentOccurrence
For Each oDoc In ThisApplication.ActiveDocument.AllReferencedDocuments
Dim filename As String = IO.Path.GetFileName(oDoc.displayname)
oDocName = oDoc.Displayname
iProperties.Value(oDocName ,"Summary", "Title") = oDocName
If iProperties.Value(oDocName ,"Summary", "Keywords") = "ISM" Then
iProperties.Value(oDocName ,"Project", "Part Number") = JOB_NUMBER & "I" & part_no & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
oDoc.Save
oDoc.Close
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_ROLL_TANGENT;IV_ARC_CENTERS"
Dim sFname As String
sFname = DXF_LOC & iProperties.Value(oDocName ,"Project", "Part Number") & ".dxf"
oCompDef.DataIO.WriteDataToFile(sOut, sFname)
part_no = part_no + 1
Next
