iLogic driving and driven dimensions
iiiocep
iiiocep
Hi everyone, I have some problems with my code:
Terms:
1. d64 - driving dimension
2. d75 - driven dimension
 Solution is:
1. Проверяем является ли параметр "d64" управляющим.
2. Если условие выполняется, то параметр "d75" нужно сделать управляемым и присвоить ему какое-то значение .
WCrihfield
What language are you using?  If you translate it to English, you may get more responses.
You can use Google Translate or https://www.translate.com/ , if needed.
Wesley Crihfield
(Not an Autodesk Employee)
iiiocep
I don't know why, but I delete the translation to English.
1. Check if the parameter "d64" is driving it works correct.
2. If the first condition is True parameter "d64" should be driving too and I need to assign new value to it.
I think I have some problems with connection of two conditions, because both conditions works separately correct.
iiiocep
Full question:
Terms:
 Solution that I tried is:
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oSketch1 As Sketch
oSketch1 = oDoc.ComponentDefinition.Sketches.Item("Sketch1")
'Loop through dimensions looking for the one named d64
For Each cDim As DimensionConstraint In oSketch1.DimensionConstraints
   If cDim.Parameter.Name = "d64" Then
        If cDim.Driven = False Then
                If cDim.Parameter.Name = "d75" Then
                If cDim.Driven = True Then
                cDim.Driven = False
     Exit For
Next
J-Camper
I think this is doing what you're asking:
Dim oDoc As PartDocument = ThisDoc.Document
Dim oSketch1 As Sketch = oDoc.ComponentDefinition.Sketches.Item("Sketch1")
'Declare Dimension Constraints
Dim DimCon1 As DimensionConstraint
Dim DimCon2 As DimensionConstraint
	If cDim.Parameter.Name = "d64" Then DimCon1 = cDim
	If cDim.Parameter.Name = "d75" Then DimCon2 = cDim
Next
'Run Logic for which Value to change
If DimCon1.Driven = True
	DimCon2.Driven = False
	'Set Value
	DimCon2.Parameter.Expression = "1 in"
Else
	'Set Value
	DimCon1.Parameter.Expression = "1 in"
'UPDATE
InventorVb.DocumentUpdate()
Let me know if you have any questions or if the code is not doing what you want.
I would recommend changing the names of Parameters you're going to write rules for instead of leaving them with the given name
iiiocep
Hi, thank's a lot for your help! You was almost right.
The code that I want to get and it works:
Next
If DimCon1.Driven = False
'Set Value DimCon2.Parameter.Expression = "a12" End If 'UPDATE InventorVb.DocumentUpdate()
