iLogic Drawing Index from Sheet Name and Number
sosborne
sosborne
I am looking for a reasonably straightforward way to take the sheet names and sheet numbers from a drawing set and automatically put them into a table on sheet one of an Inventor drawing.
I am using the code below to link a titleblock field to the sheet title so the sheet has a global title and a specific per-sheet title/description
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oTitleBlock As TitleBlock
Dim oTextBox As TextBox
Dim oSheet As Sheet
Dim lPos As Long
Dim sSheetName As String
For Each oSheet In oDoc.Sheets
	If oSheet.ExcludeFromCount = False Then
	    oTitleBlock = oSheet.TitleBlock
		lPos = InStr(oSheet.Name, ":")
		sSheetName = Left(oSheet.Name, lPos - 1)
		For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
	        If oTextBox.Text = "SHEET-NAME" Then
	            Call oTitleBlock.SetPromptResultText(oTextBox, sSheetName)
	    Next
		Else
Next
I considered exporting the sheet names and numbers to an excel file and then re-importing them but that seemed like it left more room for something to go wrong.
That said, I am stuck on moving that data into a table with a title (drawing index), 2 columns (Description and Sheet#) and adds as many rows as needed. I found a thread that referenced this code that I tried to modify but I am not able to get anything to display. Set up table with iLogic
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
oDoc = ThisDoc.Document
oSheet = oDoc.ActiveSheet
Dim oColumns As Integer
Dim oRows As Integer
oColumns = 2
i = 0
'tally the sheets that are set to be excluded
If oSheet.ExcludeFromCount = True Then
i = i + 1
Else
Next
'subtract the excluded sheet from the number of sheets in the sheet collection
oMySheetCount = oDoc.Sheets.Count - i
oRows = 1 + oMySheetCount
'calculate number of columns cells
oCells = oColumns * oRows
Dim oTitles(oColumns - 1) As String
'Hardcoded titles
oTitles(0) = "DESCRIPTION"
oTitles(1) = "SHEET #"
Dim oContents(oCells - 1) As String
Dim j As Integer
j = 0
i = 1
Do Until j = oCells
	'fill cell data
	If j = 0 Then
		oContents(j) = "Groef"
	ElseIf j = 6 Then
		oContents(j) = "Zetting"
	ElseIf j = 7 Then
		oContents(j) = "Aanslag"
	ElseIf j = 8 Then
		oContents(j) = "Zet Lengte"
	ElseIf j = 9 Then
		oContents(j) = i
		i = i + 1
	ElseIf j > 9
		If j = 9 + (i - 1) * 3 Then
			oContents(j) = i
			i = i + 1
		Else
			oContents(j) = ""
	Else
		oContents(j) = ""
	j = j + 1
Loop
Dim InsP As Point2d
InsP = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
Dim oCustomTable As CustomTable
oCustomTable = oSheet.CustomTables.Add("DRAWING INDEX", InsP, oColumns, oRows, oTitles, oContents)
I do not get any errors but I also do not get a table on the sheet or in the styles menu. In this application I think the loop is not needed but I wanted to see if I could get the code to work before stripping it out so I have left it in place for now.
Sean
A.Acheson
The table was being added on a different sheet other than sheet 1. Here is a working example. Hopefully you can follow it's construction. Any questions I will be happy to help.
Dim oSheet, oIndexSheet As Sheet
Dim sSheetName, sSheetNo As String
oIndexSheet = oDoc.Sheets(1)'In order to put table on sheet 1
oIndexSheet.Activate
oIndexSheet.ExcludeFromCount = True
'[Table Setup
Dim oColumns,oRows,oCells,i As Integer
oColumns = 2
i = 0
oRows = oDoc.Sheets.Count - 1
oCells = oColumns * oRows 'calculate number of cells
Dim oContents(oCells - 1) As String 'Minus 1 as array will start from zero
Dim oTitles(oColumns - 1) As String 'Minus 1 as array will start from zero
'Hardcoded titles
	If oSheet.ExcludeFromCount = False Then 'Avoid processing index page
		sSheetNo = Right(oSheet.Name, 1)
	    Next
		'[Table Data
		oContents(i) = sSheetName 'Add to string
		i = i+1
		oContents(i) = sSheetNo  'Add to string
		i = i+1
	Else
Next
Dim InsP As Point2d
oCustomTable = oIndexSheet.CustomTables.Add("DRAWING INDEX", InsP, oColumns, oRows, oTitles, oContents)
Regards
Alan
sosborne
That worked brilliantly, thanks so much! I am embarrassed that I missed the table being on the wrong sheet. Is there a way to do a conditional statement that checks for an existing table and either deletes/replaces it or updates? Something like
if; table exists then update/delete table
else; create table
Sean
A.Acheson
Something like check for count of tables in the sheet with certain title then delete if found. This involves looping through the sheets.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
For i = 1 To oSheet.CustomTables.Count
    TableTitle = oSheet.CustomTables.Item(i).Title
    If TableTitle = "ASSEMBLY ORDERS" Then
        TableNr = i
	oSheet.CustomTables.Item(i).Delete
        GoTo CreateTable
Next
'if not found go create it
CreateTable:
'Declare my custom table
'*************** Add table here***********
if you know where the table is by giving the sheet number and there is only one custom table  then delete directly. You should be able to tack the if statement check if exists portion on to the end of your rule just before table creation.
If oIndexSheet.CustomTables.Count = 1 Then
	oCustomTable = oIndexSheet.CustomTables.Item(1)
	oCustomTable.Delete
Else
'oCustomTable = oIndexSheet.CustomTables.Add("DRAWING INDEX", InsP, oColumns, oRows, oTitles, oContents)
Regards
Alan
farshidDWRFR
Hello everyone,
Not sure if this is the right place to ask this question, so please let me know if it is not.
I am trying to write an iLogic snippet that asks the user for a number as the start page number for a document containing multiple drawing pages and then changes sheet numbers' beginning to that number. For example, I want my drawing sheet numbers to start from 20 instead of 1. I would like to use the sheet number in the title block afterwards.
Thanks in advance for your help
