Ilogic drawing dimension
I am using this code create the dimension with parameter but get error when I put the variables in the Parameter.
'Get active drawing document, sheet and view
Dim drwDoc As DrawingDocument = ThisDoc.Document
Dim drwSheet As Sheet = drwDoc.Sheets(1)
Dim drwView As DrawingView = drwSheet.DrawingViews(1)
'Get referenced assembly and its component definition
Dim asmDoc As AssemblyDocument = drwDoc.ReferencedDocuments(1)
Dim asmDef As AssemblyComponentDefinition = asmDoc.ComponentDefinition
'Get MateConstraint
Dim mateConstraint As MateConstraint = asmDef.Constraints("MateForDimension")
'Get face proxies from MateConstraint
Dim faceProxy1 As FaceProxy = mateConstraint.EntityOne
Dim faceProxy2 As FaceProxy = mateConstraint.EntityTwo
'Get DrawingCurves which belongs to face in appropriate DrawingView
Dim curves1 As DrawingCurvesEnumerator = drwView.DrawingCurves(faceProxy1)
Dim curves2 As DrawingCurvesEnumerator = drwView.DrawingCurves(faceProxy2)
'Select the right DrawingCurve
Dim curve1 As DrawingCurve = curves1.Item(1)
Dim curve2 As DrawingCurve = curves2.Item(1)
'Create GeometryIntent for this curve
Dim geometryIntent1 = drwSheet.CreateGeometryIntent(curve1)
Dim geometryIntent2 = drwSheet.CreateGeometryIntent(curve2)
'Select dimension text position
Dim textOrigin = drwView.Center
'Create DrawingDimension
drwSheet.DrawingDimensions.GeneralDimensions.AddLinear(textOrigin, geometryIntent1, geometryIntent2)
floccipier
@Anonymous this is really creative way to access intent faces. Would you mind sharing what error you encounter?
When I used the parameter which has variable in it. it will case error.
