iLogic - Disabling section for parts from assembly level
lukasz.badowski
lukasz.badowski
Hi Everyone,
I try do iLogic rule that disable participate sections for selected parts in assembly. Below picture with that what i mean.
Below is my rule. I try Set my setting for parts form ObjectCollection, and I receive some errors.
Can anyone get me some tips?
Dim oDocAssem As AssemblyDocument
oDocAssem = ThisApplication.ActiveDocument
Dim oSelected As ObjectCollection
oSelected = ThisApplication.TransientObjects.CreateObjectCollection
Dim oCount As Long
oCount = oDocAssem.SelectSet.Count
If oCount = 0 Then
	MessageBox.Show("Select one or more part.", "iLogic")
	Return
Dim i As Integer
For i = 1 To oCount
	If oDocAssem.SelectSet.Item(i).Type = _
		ObjectTypeEnum.kComponentOccurrenceObject Then
		oSelected.Add (oDocAssem.SelectSet.Item(i))
Next
Dim oDoc As Document
For Each oDoc In oSelected
Dim oPartDoc As PartDocument
oPartDoc = oDoc
  'Disable the part section.
  oPartDoc.ModelingSettings.AllowSectioningThruPart = False
Next
MessageBox.Show("Done!", "iLogic")
WCrihfield
Try it this way.
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
oSS = oADoc.SelectSet
If oSS.Count > 0 Then
	For i As Integer = 1 To oSS.Count
		If oSS.Item(i).Type = ObjectTypeEnum.kComponentOccurrenceObject Then
			Dim oComp As ComponentOccurrence = oSS.Item(i)
			If oComp.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
				Dim oPartDoc As PartDocument = oComp.Definition.Document
	Next
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES" 👍.
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
  • Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
  • Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
  • Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
  • Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
  • Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
  • SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
  • Create DocumentSubTypeEnum Click Here
  • Add kRevisionTag or kDrawingRevisionTag to ObjectTypeEnum Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
lukasz.badowski
It is not perfect solution, because selection more than one part makes error, but it is step forward and great tip.
WCrihfield
It might be more stable and work better for multiple selections if, instead of SelectSet, you used a Do While...Loop with the Pick command, which adds each Picked item to a ObjectCollection, until you answer No to a simple question (or select Nothing, or similar).
Then just define each object in the ObjectCollection as a ComponentOccurrence, before the loop to set the AllowSectioningThruPart setting.
Try it this way to see if it works any better for you.
Dim oOC As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim oObj As Object
Dim oContinue As Boolean = True
Dim oAns As MsgBoxResult
Do While oContinue = True
	oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a Component Occurrence.")
	If oObj Is Nothing Then Exit Do
	oOC.Add(oObj)
	'oOC.Add(ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter))
	oAns = MsgBox("Do you want to add another selection?", vbYesNo + vbQuestion, "COMPONENT OCCURRENCES")
	If oAns = vbNo Then oContinue = False
Loop
For Each oObj In oOC
	Dim oCO As ComponentOccurrence = oObj
	If oCO.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
		Dim oPartDoc As PartDocument = oCO.Definition.Document
Next
Wesley Crihfield
lukasz.badowski
Hi WCrihfield,
Now it work perfect!
Thank You for help.
