iLogic dimension accuracy
Message 1 of 10
Hi.
I am automating part drawings in Inventor using iLogic.  I want the idw drawing to display dimensions to either zero Decimal places or one Decimal place depending on the dimensions value.  e.g. if the dimension is 124mm I want to see 124 (not 124.0).  If it is 124.1mm I want to see 124.1 (or if is it 124.1038976 I want to see 124.1).
Is there a bit of iLogic code that can do this?
Terry
Accepted solutions (3)
Replies (9)
Message 2 of 10
Sergio.D.Suárez
Hi, try the following ilogic rule, I try to do what you need.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
For Each oDim As DrawingDimension In oSheet.DrawingDimensions
	If Round(oDim.ModelValue * 10, 1) -Round(oDim.ModelValue * 10, 0) = 0 Then
		oDim.Precision = 0
	Else
		oDim.Precision = 1
Next
 I hope this helps with your work. Grettings!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 10
Thanks a million Sergio.
That is exactly what I was after!!
Cheers,
Terry
Message 4 of 10
Hi.
My original question was answered (thank you Sergio) but I now have another similar and related question.
I am picking up the volume from the ipt iProperties and converting it to a custom iProperty for display in a text box on the idw drawing.  I have a bit of iLogic code to convert the volume to dm3 and ensure that three decimal places are displayed even when some/all of the D.P.s are zeros e.g. 12.000, 12.100, 12.110.
iProperties.Value("Custom", "Vol (dm3)") = (Format(Round(iProperties.Volume / 1000000, 3),".000"))
I now also need to ensure that the "integer part" of the decimal (left of the decimal point) displays as a number even if it is zero.
e.g. at the moment any number => 1 displays fine.  If the volume is 0.952 it displays as .952 and drops the zero.  Is there a bit of code anywhere that will ensure that the 0 is displayed in this circumstance?
Many thanks,
Terry
Message 5 of 10
Sergio.D.Suárez
Hi, I think you could use two paths for what you need.
If you define the property as a number, you do not need changes and the rule would look like this
Dim oValue As Double = (Format(Round(iProperties.Volume / 1000000, 3), ".000"))
iProperties.Value("Custom", "Vol (dm3)") = oValue
however, if you define the property as text you should use something like the following
Dim oValue As String = (Format(Round(iProperties.Volume / 1000000, 3), ".000"))
If oValue < 1 Then
	iProperties.Value("Custom", "Vol (dm3)") = "0" & oValue
Else
 I hope this helps with your problem. regards
Mechanical Designer
Message 6 of 10
Thanks very much Sergio
I will give it a try and let you know
Message 7 of 10
Hi Sergio.
The second option worked perfectly for what I wanted to do!!
Thanks again
Terry
Message 8 of 10
Formsprag
How would I apply this rule to specific dimensions in a rule?  Let's say I want dimensions 1-4 to be 1 decimal, 5-8 to be 2 decimals and 9-15 to be 3 decimals. Is that possible?
Message 9 of 10
ganeshholkar18
I have used this iLogic rule to update dimension precision on drawing and it works fine.
Now what I need is I need this rule to be applied only for one view on drawing and remaining view on drawing should remain with zero "0" precision.
The view which should only be precise has name "UNDER". Is it possible to modify below iLogic rule for this requirement??
		oDim.Precision = 0
	Else
		oDim.Precision = 1
Next
BR, Ganesh Holkar
Message 10 of 10
kirupakaranmech
Observer
Observer
Could please share alternate unit precision control i logic rule?
