Yes, there is, I just made my tool last week. (well i used a really great source and modified it a bit.)
You should look at: C:\Users\Public\Documents\Autodesk\Inventor 2014\SDK\UserTools\CopyDesign
This is the code from source, but to better understand it, you should run it in debug.
I modified the file saving location part.
Public Class Form1
Private Sub btnBrowse_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnBrowse.Click
' Get the full path of the folder of the existing design.
dlgFolderBrowser.Description = "Select path of existing files."
dlgFolderBrowser.ShowDialog()
Dim filePath As String
filePath = dlgFolderBrowser.SelectedPath
' Check to see that a path was specified.
If filePath <> "" Then
' Set the text field to the specified path.
txtDirectoryPath.Text = filePath
' Update the displayed path of the new project.
UpdateNewProjectName()
End Sub
Private Sub txtDirectoryPath_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles txtDirectoryPath.TextChanged
End Sub
Private Sub txtNewName_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles txtNewName.TextChanged
End Sub
Private Sub UpdateNewProjectName()
' Strip off the last directory from the full path.
Dim fullPath As String = txtDirectoryPath.Text
fullPath = fullPath.Substring(0, fullPath.LastIndexOf("\") + 1)
lblNewDesignPath.Text = fullPath & txtNewName.Text
' Update the pre-pend name for the file names to be copied.
If chkPrependDesignNameToFileNames.Checked Then
txtPrependDesignName.Text = txtNewName.Text
End Sub
Private Sub btnCancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnCancel.Click
Me.Close()
End Sub
Private Sub btnOK_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnOK.Click
' Disable the buttons while it's processing
btnOK.Enabled = False
btnCancel.Enabled = False
Try
' Validate that the specified path for the existing project exists.
If Not System.IO.Directory.Exists(txtDirectoryPath.Text) Then
MsgBox("The specified path to the existing design does not exist.")
Exit Sub
' Check to see if the specified path for the new project exists.
If System.IO.Directory.Exists(lblNewDesignPath.Text) Then
If MsgBox("The specified path for the new design already exists. Any existing files in this directory may be overwritten. Do you want to continue?", MsgBoxStyle.YesNo + MsgBoxStyle.Question) = MsgBoxResult.No Then
Exit Sub
Else
' Create the output directory.
Try
System.IO.Directory.CreateDirectory(lblNewDesignPath.Text)
Catch ex As Exception
MsgBox("Unable to create the directory for the new design: """ & lblNewDesignPath.Text & """")
Exit Sub
End Try
' Get the name of the existing design by getting the name of the directory from the full path.
Dim existingDesignName As String = fullPath.Substring(fullPath.LastIndexOf("\") + 1)
' Get the name of the new design.
Dim newDesignName As String = txtNewName.Text
' Get the full path of the base directory
Dim baseDirectoryPath As String = fullPath.Substring(0, fullPath.LastIndexOf("\") + 1)
' Get the filenames of any drawings.
'Dim drawingFilenames() As String = System.IO.Directory.GetFiles(baseDirectoryPath & existingDesignName, "*.idw")
Dim idwdrawingFilenames() As String = System.IO.Directory.GetFiles(baseDirectoryPath & existingDesignName, "*.idw")
Dim dwgDrawingFilenames() As String = System.IO.Directory.GetFiles(baseDirectoryPath & existingDesignName, "*.dwg")
Dim drawingFilenames(idwdrawingFilenames.Length + dwgDrawingFilenames.Length - 1) As String
Dim i As Long
For i = 0 To idwdrawingFilenames.Length - 1
drawingFilenames(i) = idwdrawingFilenames(i)
Next
Dim j As Long
For j = 0 To dwgDrawingFilenames.Length - 1
drawingFilenames(idwdrawingFilenames.Length + j) = dwgDrawingFilenames(j)
Next
' Create an instance of Apprentice.
Dim apprenticeServer As New Inventor.ApprenticeServerComponent
' Iterate through the drawing documents. This assumes that all other documents
' are somehow referenced by the drawings. This can be an indirect reference. For
' example, a part that is used in an assembly that is shown in the drawing is ok.
Dim currentDrawingFilename As String
For Each currentDrawingFilename In drawingFilenames
' Open the drawing in Apprentice.
If currentDrawingFilename.Substring(currentDrawingFilename.Length - 3) = "dwg" Then
'Skip the file if it's not an Inventor DWG.
If Not apprenticeServer.FileManager.IsInventorDWG(currentDrawingFilename) Then
Continue For
Dim drawingDoc As Inventor.ApprenticeServerDocument
drawingDoc = apprenticeServer.Open(currentDrawingFilename)
' Get the FileSaveAs object.
Dim fileSaveAs As Inventor.FileSaveAs = apprenticeServer.FileSaveAs
' Add the drawing to the FileSaveAs object.
Dim newDrawingFilename As String = drawingDoc.FullFileName
newDrawingFilename = baseDirectoryPath + newDesignName + "\" + newDrawingFilename.Substring(fullPath.Length + 1)
' Prepend design name to filename
If txtPrependDesignName.Text <> "" Then
Dim prependPos As Integer = newDrawingFilename.LastIndexOf("\") + 1
newDrawingFilename = newDrawingFilename.Substring(0, prependPos) + txtPrependDesignName.Text + "_" + newDrawingFilename.Substring(prependPos, newDrawingFilename.Length - prependPos)
' Delete the document in case it already exists.
If System.IO.File.Exists(newDrawingFilename) Then System.IO.File.Delete(newDrawingFilename)
fileSaveAs.AddFileToSave(drawingDoc, newDrawingFilename)
' Copy all the referenced OLE files and re-reference the new copied ones to the drawing document.
Dim referencedOLEFileDes As Inventor.ReferencedOLEFileDescriptor
For Each referencedOLEFileDes In drawingDoc.ReferencedOLEFileDescriptors
replaceOLEReferencedFiles(referencedOLEFileDes, existingDesignName, newDesignName)
Next
' Get all of the documents referenced by this document.
Dim allReferencedDocs As Inventor.ApprenticeServerDocuments
allReferencedDocs = drawingDoc.AllReferencedDocuments
Dim referencedDoc As Inventor.ApprenticeServerDocument
For Each referencedDoc In allReferencedDocs
' Get the full filename of the current document.
Dim designFilename As String = referencedDoc.FullFileName
' Replace instances of the old design name with the new name.
designFilename = baseDirectoryPath + newDesignName + "\" + designFilename.Substring(fullPath.Length + 1)
Dim prependPos As Integer = designFilename.LastIndexOf("\") + 1
designFilename = designFilename.Substring(0, prependPos) + txtPrependDesignName.Text + "_" + designFilename.Substring(prependPos, designFilename.Length - prependPos)
' Check to see if the specified path for the file exists.
If Not System.IO.Directory.Exists(designFilename.Substring(0, designFilename.LastIndexOf("\") + 1)) Then
Try
System.IO.Directory.CreateDirectory(designFilename.Substring(0, designFilename.LastIndexOf("\") + 1))
MsgBox("Unable to create the directory for the file: """ & designFilename & """")
Exit Sub
End Try
' Add the current file to the FileSaveAs object.
fileSaveAs.AddFileToSave(referencedDoc, designFilename)
If System.IO.File.Exists(designFilename) Then System.IO.File.Delete(designFilename)
For Each referencedOLEFileDes In referencedDoc.ReferencedOLEFileDescriptors
Next
Next
' Do the save copy as of all the files.
fileSaveAs.ExecuteSaveCopyAs()
' Close the drawing.
referencedDoc.Close()
Next
apprenticeServer.Close()
Next
MsgBox("Finished copying design.")
MsgBox("Unexpected error while processing files.")
End Try
btnOK.Enabled = True
btnCancel.Enabled = True
End Sub
Private Sub chkPrependDesignNameToFileNames_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles chkPrependDesignNameToFileNames.CheckedChanged
Else
txtPrependDesignName.Text = ""
End Sub
' Copy and replace the OLE referenced files
Private Sub replaceOLEReferencedFiles(ByRef referencedOLEFileDes As Inventor.ReferencedOLEFileDescriptor, ByVal existingDesignName As String, ByVal newDesignName As String)
' only linked OLE files will be copied and re-referenced to new design documents.
If referencedOLEFileDes.OLEDocumentType = Inventor.OLEDocumentTypeEnum.kOLEDocumentLinkObject Then
' Get the full filename of the referenced OLE file.
Dim originDesignOLEFileName As String = referencedOLEFileDes.FullFileName
Dim designOLEFileName As String = originDesignOLEFileName
If System.IO.File.Exists(originDesignOLEFileName) Then
' Replace the old design name with new name.
designOLEFileName = baseDirectoryPath + newDesignName + "\" + designOLEFileName.Substring(fullPath.Length + 1)
If Not (System.IO.Directory.Exists(designOLEFileName.Substring(0, designOLEFileName.LastIndexOf("\")))) Then
System.IO.Directory.CreateDirectory(designOLEFileName.Substring(0, designOLEFileName.LastIndexOf("\")))
Dim prependPos As Integer = designOLEFileName.LastIndexOf("\") + 1
designOLEFileName = designOLEFileName.Substring(0, prependPos) + txtPrependDesignName.Text + "_" + designOLEFileName.Substring(prependPos, designOLEFileName.Length - prependPos)
System.IO.File.Copy(originDesignOLEFileName, designOLEFileName, True)
' reference to new OLE files.
referencedOLEFileDes.FileDescriptor.ReplaceReference(designOLEFileName)
End Sub
End Class
If you use content center parts (which are not allowed for this code) see this link.
http://forums.autodesk.com/t5/inventor-customization/sdk-copy-design-amp-content-center-parts/m-p/58...
If you need more info just just let me know.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
