ilogic - delete sub assembly
Simon.robertsX5M9D
Simon.robertsX5M9D
Hi peeps
need help with deleting a sub assembly with in a main Assembly by using ilogic
In my main assembly have handled sub assembly, like to  choice the option to delete one
Can this be done by ilgoic and can it to done by the prefix of the assembly name example 027-00000-201 or 027-00000-0200 ( really like to control it by either 200 or 201 on the end of the file name)
thanks
JhoelForshav
Hi @Simon.robertsX5M9D
Are you looking for something like this? 🙂
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
For Each oOcc As ComponentOccurrence In oDef.Occurrences
	If oOcc.Definition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject
		Dim oName = System.IO.Path.GetFileNameWithoutExtension(oOcc.ReferencedDocumentDescriptor.DisplayName)
		Dim Last3 As String = oName.Substring(oName.Length - 3)
		If Last3 = "200" Or Last3 = "201"
			Dim oDelete As DialogResult = MessageBox.Show("Delete " & oOcc.Name, "Delete Sub Assembly?", MessageBoxButtons.YesNo)
			If oDelete = DialogResult.Yes Then oOcc.Delete
Next
