(iLogic) Delete Ordinate Dimension Set Member
JoãoASilva
Message 1 of 26
JoãoASilva
Hello all,
I'm trying to delete an Ordinate Dimension Set member with iLogic.
I can delete the whole Dimension Set if there is a "sick" dimension, but that would give me even more work 😄
I tried deleting unattached center marks first, but it doesn't solve anything.
Any tips?
João Silva
Mechanical Engineer
Replies (25)
Message 21 of 26
MjDeck
@JoãoASilva , there was a change in Inventor 2021. To fix a problem (internal number INVGEN-34263), we changed it so that if any member dimension  shows Attached = False then they all do.
If you happen to delete all the members that are truly detached, then the set as a whole will be attached. At that time, the remaining members will show up as attached.
This makes it very hard to find the members that are truly detached. It looks like we should restore the behavior of Inventor 2020 and earlier.
For now, you can work around the problem with the attached rule. This is based on @dutt.thakar's rule. Instead of looking at the Attached property, it looks at other properties of the dimension to see if it's valid or not. In some cases it needs to know the positions of detached centermarks.
This rule might need to be generalized to handle other cases.
Mike Deck
Software Developer
Autodesk, Inc.
Message 22 of 26
matt_jlt
Thanks Mike, the new behavior is definitely going to be a pain for this situation and a few other pieces of code I have written.
Can you please submit it as an issue? Because it doesn't make sense that there is no way to check that a member is attached.
Thanks, Matt.
Message 23 of 26
MjDeck
I created issue INVGEN-50619 to track this.
Also, I made a small improvement to the rule I posted above. Please use this new version instead. It adds a check to see if the Attached property of the dimension is False before diving in and looking at other properties in detail.
Mike Deck
Software Developer
Autodesk, Inc.
Message 24 of 26
JoãoASilva
Sorry for the delayed answer, I had to take a few days off because of some personal problems.
@matt_jlt , @dutt.thakar
Thank you guys for your help!
@MjDeck
Thank you for giving a clear answer to what is going on.
I was getting a little frustrated that I couldn't get it to work like matt_jlt and dutt.thakar...
I'll try your rule, and make changes as needed.
Also, is there a way, for us, to track that issue and see when it's solved?
João Silva
Mechanical Engineer
Message 25 of 26
DanioZhu
@JoãoASilva, the fix has been submitted which will be available in Inventor 2021.3 and 2022.1
Message 26 of 26
JoãoASilva
@MjDeck
The rule is working correctly, thank you again!
@DanioZhu
Got it! I'm happy I found something to help improve Inventor 😁
João Silva
Mechanical Engineer
