Ilogic - Delete Iproperties
j.wolbers-NoTech
Message 1 of 14
j.wolbers-NoTech
Is it possible to remove all Iproperties from the Summary and Project tab with an ILogic code? I now do this manually with purchase parts that we import into our system. Ideally, the code should also immediately remove everything from underlying parts if it is an assembly.
Look forward to hearing whether this is possible.
Kinds regards,
Jeffrey
Replies (13)
Message 2 of 14
marcin_otręba
You can start from something like:
Dim ass As AssemblyDocument= ThisDoc.Document
Dim j As Integer
Dim i As Integer
For i = 1 To  ass.PropertySets.Count
If ass.PropertySets.Item(i).Name = "Design Tracking Properties" Or ass.PropertySets.Item(i).Name = "Inventor Summary Information" Then
	For j = 1 To  ass.PropertySets.Item(i).Count
		Try
			ass.PropertySets.Item(i).Item(j).Value = ""
		Catch
		End Try
		Next
Next
Dim doc As Document
For Each doc In ass.AllReferencedDocuments
For i = 1 To  doc.PropertySets.Count
If doc.PropertySets.Item(i).Name = "Design Tracking Properties" Or doc.PropertySets.Item(i).Name = "Inventor Summary Information" Then
	For j = 1 To  doc.PropertySets.Item(i).Count
		Try
			doc.PropertySets.Item(i).Item(j).Value = ""
		Catch
		End Try
		Next
Next
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 14
Martin-Winkler-Consulting
@j.wolbers-NoTech
Yes it is possible!
Copy this iLogic Code in one rule and run it:
Sub Main
	Dim oDoc As Document = ThisDoc.Document
	If  oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
		Dim oPropSet As PropertySet
		For Each oPropSet In oDoc.PropertySets
		If oPropSet.Name = "Design Tracking Properties" Or
			oPropSet.Name = "Inventor Summary Information" Then
			Delete_PropSet_Contents(oPropSet)
		Next
	Else
		MsgBox("Start only in Assembly", vbCritical, "Delete Content iProperties")
	Dim oRefDoc As Document
	For Each oRefDoc In oDoc.AllReferencedDocuments
		GetRefDocs(oRefDoc)
	Next
End Sub
Sub GetRefDocs (oDoc As Document)
	Next
End Sub
Sub Delete_PropSet_Contents(oPropSet As PropertySet)
	Dim oProp As [Property]
	For Each oProp In oPropSet
		Try
		oProp.Value = ""
		Catch
		End Try
	Next
End Sub
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
Message 4 of 14
j.wolbers-NoTech
Hi @Martin-Winkler-Consulting & @marcin_otręba
Both Ilogic codes work.
No idea which one to use best.., I don't think it matters.
However, I have two more minor issues ...
  • The iLogic code does not work if you run it on a part (with an assembly and the underlying daughters it works).
  • Two more Iproperty fields remain filled in (see image)
Kinds regards,
Jeffrey
Message 5 of 14
marcin_otręba
hi,
they are not deleted because they are in "Inventor Document Summary Information" property set.
corrected ilogic (it will remove from single document as well):
If   ThisDoc.Document.SubType="{E60F81E1-49B3-11D0-93C3-7E0706000000}" Then
Dim ass As AssemblyDocument = ThisDoc.Document
Dim j As Integer
Dim i As Integer
If ass.PropertySets.Item(i).Name = "Design Tracking Properties" Or ass.PropertySets.Item(i).Name = "Inventor Summary Information" Or ass.PropertySets.Item(i).Name = "Inventor Document Summary Information" Then
		Try
		Catch
		End Try
		Next
Next
Dim doc As Document
If doc.PropertySets.Item(i).Name = "Design Tracking Properties" Or doc.PropertySets.Item(i).Name = "Inventor Summary Information" Or ass.PropertySets.Item(i).Name = "Inventor Document Summary Information" Then
		Try
		Catch
		End Try
		Next
Next
Next
Else If ThisDoc.Document.SubType <> "{E60F81E1-49B3-11D0-93C3-7E0706000000}" Then
	For i = 1 To  ThisDoc.Document.PropertySets.Count
If ThisDoc.Document.PropertySets.Item(i).Name = "Design Tracking Properties" Or ThisDoc.Document.PropertySets.Item(i).Name = "Inventor Summary Information" Or ThisDoc.Document.PropertySets.Item(i).Name = "Inventor Document Summary Information" Then
	For j = 1 To  ThisDoc.Document.PropertySets.Item(i).Count
		Try
			ThisDoc.Document.PropertySets.Item(i).Item(j).Value = ""
		Catch
		End Try
		Next
Next
Message 6 of 14
j.wolbers-NoTech
@marcin_otręba
Thank you very much for your help!
Jeffrey
Message 7 of 14
J.Classens
This ilogic rule works perfect!
I can't adjust it the way i like it.
I want this rule to work only to childeren in an assembly.
Is it possible to adjust this rule to get it work like that?
Message 8 of 14
marcin_otręba
do you mean that you want to delete only in first level of assembly components, or you do not want to delete properties in assembly itself?
Message 9 of 14
marcin_otręba
if you want to skip iproperties in assembly just delete :
Dim j As Integer
Dim i As Integer
'-------------------------------------------------delete from here
For i = 1 To ass.PropertySets.Count If ass.PropertySets.Item(i).Name = "Design Tracking Properties" Or ass.PropertySets.Item(i).Name = "Inventor Summary Information" Or ass.PropertySets.Item(i).Name = "Inventor Document Summary Information" Then For j = 1 To ass.PropertySets.Item(i).Count Try ass.PropertySets.Item(i).Item(j).Value = "" Catch End Try Next End If Next
'-----------------------------------------------------to her to leave iprop in assembly
Dim doc As Document For Each doc In ass.AllReferencedDocuments For i = 1 To doc.PropertySets.Count If doc.PropertySets.Item(i).Name = "Design Tracking Properties" Or doc.PropertySets.Item(i).Name = "Inventor Summary Information" Or ass.PropertySets.Item(i).Name = "Inventor Document Summary Information" Then For j = 1 To doc.PropertySets.Item(i).Count Try doc.PropertySets.Item(i).Item(j).Value = "" Catch End Try Next End If Next Next Else If ThisDoc.Document.SubType <> "{E60F81E1-49B3-11D0-93C3-7E0706000000}" Then For i = 1 To ThisDoc.Document.PropertySets.Count If ThisDoc.Document.PropertySets.Item(i).Name = "Design Tracking Properties" Or ThisDoc.Document.PropertySets.Item(i).Name = "Inventor Summary Information" Or ThisDoc.Document.PropertySets.Item(i).Name = "Inventor Document Summary Information" Then For j = 1 To ThisDoc.Document.PropertySets.Item(i).Count Try ThisDoc.Document.PropertySets.Item(i).Item(j).Value = "" Catch End Try Next End If Next End If
Message 10 of 14
J.Classens
@marcin_otręba
Thanks! This was exactly what i meant.
The iLogic rule works perfect for me now.
Message 11 of 14
J.Classens
We are working with this ilogic for a while and it works almost perfect for our use.
I added some extra lines to complete the ilogic rule for our use.
After clearing the properties in underlying parts i want to ad to the title a predifined text.
I use this part to do it.
Dim j As Integer
Dim i As Integer
Dim doc As Document
If doc.PropertySets.Item(i).Name =  "Inventor Summary Information"  Then
		Try
			doc.PropertySets.Item(i).Item(j).Value = "Sub part"
		Catch
		End Try
		Next
Next
Next
 The only problem is that it changed the properties of the complete propertyset.
Is it possible to change only the Title property?
Message 12 of 14
K.TRYFONIDIS
Is it possible to get a code to run it only inside part enviroment ? i would like to clean summary, project, status and custom tab.
Is it doable?
Message 13 of 14
marcin_otręba
yes it is.
You can find information about:
properties here:
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/list-all-iproperties-and-how....
about subtypes here:
https://adndevblog.typepad.com/manufacturing/2013/01/inventor-document-sub-types.html
it will be only problem with project and status tab because there is no such property set they are only showed in project and status tabs but parent propertyset named "Design Tracking Properties" is much bigger :
so to accomplish that you can use simple loop like:
it will cleanup  summary and remove all custom iproperties.
to clean project and status you need to do it like this:
prop_set = doc.PropertySets.Item("Design Tracking Properties")
prop_set.Item("name of property to clean up").Value=""
also when you have ipropert with date format then you need to set some date not to clean it up like here:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/vba-change-quot-creation-date-quot-i...
so to sum this up here is the code wit only some samples of cleaning project and status tabs:
'"4D29B490-49B2-11D0-93C3-7E0706000000" - part
'"9C464203-9BAE-11D3-8BAD-0060B0CE6BB4" sheet metal
If ThisDoc.Document.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Or ThisDoc.Document.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim doc As PartDocument = ThisDoc.Document
Dim prop_set As PropertySet = doc.PropertySets.Item("Inventor Summary Information")
For i = 1 To prop_set.Count
	prop_set.Item(i).Value=""
Next
prop_set  = doc.PropertySets.Item("Inventor Document Summary Information")
Next
If doc.PropertySets.Item("Inventor User Defined Properties").Count > 0 Then
prop_set = doc.PropertySets.Item("Inventor User Defined Properties")
Dim count As Integer= prop_set.Count
For i =0 To count
	Try
		prop_set.Item(count-i).Delete
		Catch
	End Try
Next
' project and status tabs properties clean up:
prop_set.Item("Project").Value = ""
prop_set.Item("Description").Value = ""
prop_set.Item("Part Number").Value = ""
prop_set.Item("Checked By").Value = ""
prop_set.Item("Date Checked").Value="01.01.0001"
marcin.
Message 14 of 14
marcin_otręba
ThisDoc.Document.PropertySets.Item("Inventor Summary Information").Item("Title").Value=""
