ilogic - delete flat patern
tegstette
Message 1 of 14
tegstette
Hi
I am trying to make a rule that runs through my iam and delete all flat patterns on sheet metal parts
Can someone help me out with this rule.
Here is what I have:
'define the active assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'	MessageBox.Show("Message1", "Title")
Dim oDoc As Inventor.Document
'Check all referenced docs
For Each oDoc In oAssyDoc.AllReferencedDocuments
	MessageBox.Show("Message2", "Title")
	'Dim oDoc As Inventor.Document
	Dim smpCompDef As Inventor.SheetMetalComponentDefinition
	MessageBox.Show("Message3", "Title")
	If (smpCompDef.HasFlatPattern = True) Then
			Try
				MessageBox.Show("Message4", "Title")
					smpCompDef.Delete()
				Catch
				MessageBox.Show("Message5", "Title")
			End Try
Next
'update the files
InventorVb.DocumentUpdate()
Best regards
TG
Autodesk Inventor/Vault Professional 2021
Replies (13)
Message 2 of 14
Owner2229
Hi, try this:
' Define the active assembly
' Check all referenced docs For Each oDoc As Document In oAssyDoc.AllReferencedDocuments ' Get sheet metal component definition
Dim oSMCD As Inventor.SheetMetalComponentDefinition
' Check if it has flatpattern If (oSMCD.HasFlatPattern = True) Then ' Atempt to delete it
Try oSMCD.FlatPattern.Delete Catch End Try End If Next ' Update the files InventorVb.DocumentUpdate()
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 14
tegstette
I ran it from an iam but got this error
Object reference not set to an instance of an object.
(By the way: Can the rule be run from both directly on the sheet metal and from iam?)
Best regards
TG
Message 4 of 14
Owner2229
Hi, there was one line missing about the component definition.
Now it will work in both assembly and sheetmetal part.
' Check the document type
If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        ' Check if the part is sheet metal
        If oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	    oSMCD = oDoc.ComponentDefinition
            ' Check If it has flatpattern
            If oSMCD.HasFlatPattern = True Then
                Try
                Catch
                End Try
    Next
ElseIf ThisApplication.ActiveDocument.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    ' Get the sheetmetal component definition
Dim oSMCD As Inventor.SheetMetalComponentDefinition oSMCD = ThisApplication.ActiveDocument.ComponentDefinition ' Check If it has flatpattern If oSMCD.HasFlatPattern = True Then ' Atempt to delete it Try oSMCD.FlatPattern.Delete Catch End Try End If End If ' Update the files InventorVb.DocumentUpdate()
Mike
Message 5 of 14
tegstette
Hi
Now I got this error:
Error on Line 23 : End of statement expected
in this line:
ElseIf ThisApplication.ActiveDocument.DocumentSubType.Doc​umentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Best regards
TG
Message 6 of 14
Owner2229
Hi, put a space between "Else" and "If", so it would be:
Else If ThisApplication.ActiveDocument.DocumentSubType.Doc​umentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Mike
Message 7 of 14
tegstette
I still get the same error... (tried both SM.ipt and iam)
Best regards
TG
Message 8 of 14
tegstette
I pasted you line from your last post into my rule and now it works Smiley Happy
Thank you! Works greatSmiley Happy
Best regards
TG
Message 9 of 14
Owner2229
Can you try different assembly and sheetmetal part?
I have tested it here and it works for me, so I have no idea why it doesn't for you.
Try to copy the rule from the attached text file.
Mike
Message 10 of 14
How can I delete a few specific pieces of flat pattern?
Message 11 of 14
Send me the code if you can
Message 12 of 14
Message 13 of 14
Send me the code if you can ,merci
Message 14 of 14
A.Acheson
This post is old so it would be best to reference this post and also display the code you are using.
You can filter the referenced document using the the  display name.
 For Each oDoc As Document In xDoc.AllReferencedDocuments
If oDoc.DisplayName = “Insert part name here” Then
‘……..Insert rest of code here
Next
The display name is the browser name of the part in the assembly This example shows it use.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-display-name/td-p/9135009
Regards
Alan
