iLogic created dimensions incorrect format in AutoCAD export
rhasell
Advisor Advisor
rhasell
Hi All
The problem:
I have just written some iLogic code to automatically create an arc length dimension.
When I export my drawing to AutoCAD, the dimension is not formatted correctly.
The fix: In Inventor, edit the dimension and then close the dimension dialog box. I don’t have to do anything, just double click on the dimension and then click OK. Then it formats the dimension in AutoCAD correctly.
Is there something I can add to my code to do this automatically?
I will add a small section of code, which will prompt the user for a dimension value and place it on the drawing. This still presents the same problem when exporting to AutoCAD.
Please refer to the ScreenCast
Dim oDoc As DrawingDocument = ThisDrawing.Document
Dim oSSet As SelectSet = oDoc.SelectSet
oSym = "<StyleOverride Font='AIGDT' FontSize='0.25'>" & Chr(94) & "</StyleOverride>"
Dim oValue As String=""
If oSSet.Count = 0 Then
    MessageBox.Show("Select at least one dimension please", "iLogic", _
        MessageBoxButtons.OK,MessageBoxIcon.Information)
Else
oValue = InputBox("Enter the Dimension Value", "iLogic", oValue)
    For Each obj As Object In oSSet
            Dim oDim As GeneralDimension=obj
            Dim oDimensionText As DimensionText = oDim.Text
			oDim.HideValue = True
			oDimensionText.LineSpacingType = (29185) ' this is the correct string to format the line for "Exact"
			oDimensiontext.HorizontalJustification = (19969) ' this is the correct string to format the line for "Center Justifictaion"
			oDimensionText.LineSpacing = ("0.25") ' This will set the dimension text to Exactly of 0.25\
			oDimensionText.FormattedText = oSym & "<br/>" & oValue
					Next
Regards
Reg
2026.1
rhasell
Apologies, the  screencast did not post
Reg
2026.1
rhasell
Okay fixed.
I had to format the colour of the dimension text. It will then export the dimension on the correct layer and colour.
(Note the code below is a snippet of a much larger rule set, it is proof of concept only)
The colour was really messing me around, because all automatically created dimensions have to be edited first.
Dim oValue As String = ""
'Define colour
'Note: The export to Autocad was not formatting the Text correctly.
Dim oColor As Color
'set color to black
oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
oColor.ColorSourceType = ColorSourceTypeEnum.kLayerColorSource
	MessageBoxButtons.OK, MessageBoxIcon.Information)
Else
		Dim oDim As GeneralDimension = obj
		oDimensionText.HorizontalJustification = (19969) ' this is the correct string to format the line for "Center Justifictaion"
		oDimensionText.Color = oColor
	Next
Reg
2026.1
