iLogic create Table within Excel
checkcheck_master
Message 1 of 12
checkcheck_master
How can I create a Table within an Excel document through iLogic?
In VBA it works fine but I don't know how to put it to iLogic.
I have this in VBA:
Private Sub CreateTable(ByVal oExcelApp As Excel.Application, ByVal oWB As Workbook, ByVal TableStyle As String)
    Dim oWs As WorkSheet
    Set oWs = oWB.ActiveSheet
    ' Get Last Row and Last Column as numbers
    Dim LR As Long
    Dim LC As Long
    LR = oWs.Cells(oWs.Rows.Count, 1).End(xlUp).row
    LC = oWs.Cells(1, oWs.Columns.Count).End(xlToLeft).column
    ' Create Table
    Dim rng As Range
    Set rng = oWs.Cells(1, 1).Resize(LR, LC)
    oWs.ListObjects.Add xlSrcRange, xllistobjecthasheaders:=xlYes, Destination:=rng
    oWs.ListObjects(1).Name = "Table"
    oWs.ListObjects(1).TableStyle = TableStyle '"TableStyleLight21"
    Set oWs = Nothing
    Set oWB = Nothing
    Set oExcelApp = Nothing
End Sub
 Called by:
Call CreateTable(oExcelApp, oWB1, "TableStyleLight10")
Replies (11)
Message 2 of 12
WCrihfield
Hi @checkcheck_master.  The main difficulty in converting this to iLogic, is how to setup/call out the references/imports, so it knows what Excel and its objects are.  This is done within the 'Header' area of an iLogic rule.  I also often prefer to use a separate custom Function just to 'get' the Excel application object, depending on the situation.  Here is an iLogic rule conversion of your VBA macro, that I have included the header content and the custom Function I like to use.  (The first 3 lines will automatically transfer themselves into the header area.)
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop
Imports Microsoft.Office.Interop.Excel
Sub Main
	Dim oExcelApp As Microsoft.Office.Interop.Excel.Application = GetExcel
	Dim oWB1 As Workbook = oExcelApp.ActiveWorkbook
End Sub
    Dim oWs As WorkSheet = oWB.ActiveSheet
    Dim LR As Long = oWs.Cells(oWs.Rows.Count, 1).End(xlUp).row
    Dim LC As Long = oWs.Cells(1, oWs.Columns.Count).End(xlToLeft).column
    ' Create Table
    Dim rng As Range = oWs.Cells(1, 1).Resize(LR, LC)
    oWs.ListObjects.Add(xlSrcRange, xllistobjecthasheaders:=xlYes, Destination:=rng)
    oWs = Nothing
    oWB = Nothing
    oExcelApp = Nothing
End Sub
Function GetExcel() As Microsoft.Office.Interop.Excel.Application
	Dim oXL As Microsoft.Office.Interop.Excel.Application
	Try
		'try to find an already running instance of the Excel Application
		oXL = GetObject(, "Excel.Application")
	Catch
		'it wasn't found open, so create an instance of it (start the application)
		oXL = CreateObject("Excel.Application")
		'oXL = New Microsoft.Office.Interop.Excel.Application
	Catch
		MsgBox("Failed to Get/Create an instance of the Excel Application. Exiting.", , "")
		Exit Function
	End Try
	Return oXL
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 12
checkcheck_master
Thanks a lot WCrihfield.
I can't get it to work.
Tried several things, but no luck.
It crashes in 'Private Sub CreateTable'.
See image of the error message.
Could it be something to do with Excel's language/format?
I use a Dutch language version.
Changed the '1' to 'A' but it's not it.
See code:
Sub Main()
	' Try to Renumbers Item number:
	' - For Structured BOM only FirstLevel is working now
	' - For PartsOnly BOM it' working
	' - Now two(2) List are created, it's more efficient to create the two Lists in one(1) itteration
	iLogicVb.RunExternalRule("Renumber_and_Sort_BOM_Item_Numbers")
'You can change the output path by editing CSVpath below
'CSVpath = ("C:\Inventor\") 'If you change the path, remember to keep a \ at the end
'CSVpath = ThisDoc.Path + "\"
'Adapted from Inventor API Samples by Clint Brown @ClintBrown3D
'iLogic code Originally posted at https://clintbrown.co.uk/bom-export-with-ilogic
oDoc = ThisDoc.ModelDocument
'Ensure that we are in an Assembly file - Exit if not
If oDoc.DocumentType = kPartDocumentObject Then
	MessageBox.Show("You need to be in an Assembly to Export a BOM", "@ClintBrown3D iLogic")
	Return
End If
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
'You can change the output path by editing CSVpath below - by default the path is the same as the assembly file
MessageBox.Show(CSVpath)
'Get user input for Export Type:
Dim MyArrayList As New ArrayList
MyArrayList.Add("")
MyArrayList.Add("Structured - All Levels")
MyArrayList.Add("")
MyArrayList.Add("Structured - Single Level")
MyArrayList.Add("")
MyArrayList.Add("Parts Only - (Shows components in a flat list)")
ClintsBoMExporter = InputListBox("Choose a BoM type to Export: " & ClintBrown3D , MyArrayList, d0, Title := "@ClintBrown3D: BoM Export ", ListName := "BoM Type")
If ClintsBoMExporter = "Structured - All Levels" Then :GoTo GoAllLevelsExport : End If
If ClintsBoMExporter = "Structured - Single Level" Then :GoTo GoSingleLevelsExport : End If
If ClintsBoMExporter = "Parts Only - (Shows components in a flat list)" Then : GoTo GoPartExport : End If
If ClintsBoMExporter = "" Then : Return : End If
'STRUCTURED BoM ALL LEVELS:
GoAllLevelsExport:
' the structured view to 'all levels'
	oBOM.StructuredViewFirstLevelOnly = False
' Make sure that the structured view is enabled.
	oBOM.StructuredViewEnabled = True
	Dim oStructuredBOMView As BOMView
	oStructuredBOMView = oBOM.BOMViews.Item("Structured")
' Export the BOM view to an Excel file
	Dim BoM As String
	BoM = CSVpath + ThisDoc.FileName(False) + " STRUCTURED BoM ALL LEVELS.xlsx"
    oStructuredBOMView.Export(CSVpath + ThisDoc.FileName(False) + " STRUCTURED BoM ALL LEVELS.xlsx", kMicrosoftExcelFormat)
	'oStructuredBOMView.Export(BoM, kMicrosoftExcelFormat)
GoTo GoLaunch:
'STRUCTURED BoM Single Level
GoSingleLevelsExport:
	oBOM.StructuredViewFirstLevelOnly = True
	BoM = CSVpath + ThisDoc.FileName(False) + " STRUCTURED BoM Single Level.xlsx"
   'oStructuredBOMView.Export(CSVpath + ThisDoc.FileName(False) + " STRUCTURED BoM Single Level.xlsx", kMicrosoftExcelFormat)
GoTo GoLaunch:
'PARTS ONLY BoM
GoPartExport:
	oBOM.PartsOnlyViewEnabled = True
	Dim oPartsOnlyBOMView As BOMView
	oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
	BoM = CSVpath + ThisDoc.FileName(False) + " PARTS ONLY BoM.xlsx"
	oPartsOnlyBOMView.Export(CSVpath + ThisDoc.FileName(False) + " PARTS ONLY BoM.xlsx", kMicrosoftExcelFormat)
GoTo GoLaunch:
'Get user input - do you want to see the BoM?
GoLaunch :
'	i = MessageBox.Show("Preview the BOM?", "@ClintBrown3D iLogic", MessageBoxButtons.YesNo)
'	If i = vbYes Then : launchviewer = 1 : Else : launchviewer = 0 : End If
'	'If launchviewer = 1 Then ThisDoc.Launch(CSVpath + ThisDoc.FileName(False) + ".xlsx")
'	If launchviewer = 1 Then ThisDoc.Launch(CSVpath + ThisDoc.FileName(False) + " STRUCTURED BoM ALL LEVELS.xlsx")
		' Define the file to create/open
		'myXLS_File = "C:\Temp\Best_Excel_File_Ever.xls"
		myXLS_File = (CSVpath + ThisDoc.FileName(False) + " STRUCTURED BoM ALL LEVELS.xlsx")
		' Get the Inventor user name From the Inventor Options
		myName= ThisApplication.GeneralOptions.UserName
		' Define Excel Application object
		'excelApp = CreateObject("Excel.Application")
		Dim ExcelApp As Microsoft.Office.Interop.Excel.Application = GetExcel
		' Set Excel to run visibly, change to false if you want to run it invisibly
		excelApp.Visible = True
		' Suppress prompts (such as the compatibility checker)
		excelApp.DisplayAlerts = False
		' Check for existing file
		If Dir(myXLS_File) <> "" Then
		' Workbook exists, open it
		excelWorkbook = excelApp.Workbooks.Open(myXLS_File)
		ExcelSheet = excelWorkbook.Worksheets(1)
		Else
		' Create a new spreadsheet from template
		'excelWorkbook = excelApp.Workbooks.Add (Template: = "C:\Temp\Best_Excel_Template_Ever.xlt")
		End If
		'Dim ExcelApp As Microsoft.Office.Interop.Excel.Application = GetExcel
		Dim oWB1 As Workbook = excelApp.ActiveWorkbook
		CreateTable(excelApp, oWB1, "TableStyleLight12")
		' Insert data into Excel.
'		With excelApp
'			.Range("A1").Select
'			.ActiveCell.FormulaR1C1 = "Hello, " & myName
'		End With
		' Set all of the columns to autofit
		excelApp.Columns.AutoFit
		' Save the file
		'excelWorkbook.SaveAs (myXLS_File)
		'' Close the workbook and the Excel Application
		'' Uncomment if you want to close the xls file at the end
		'excelWorkbook.Close
		'excelApp.Quit
		'excelApp = Nothing
	End Sub
    Dim LR As Long ' = oWs.Cells(oWs.Rows.Count, "A").End(xlUp).row
    Dim LC As Long ' = oWs.Cells(1, oWs.Columns.Count).End(xlToLeft).column
        LR = oWs.Rows(oWs.Rows.Count).Row
        LC = oWs.Columns(oWs.Columns.Count).Column
'	'Sub LastRowInOneColumn()
''Find the last used row in a Column: column A in this example
'    Dim LR As Long
'    With ActiveSheet
'        LR = .Cells(.Rows.Count, "A").End(xlUp).Row
'    End With
'    'MsgBox LastRow
''End Sub
''Sub LastColumnInOneRow()
''Find the last used column in a Row: row 1 in this example
'    Dim LC As Integer
'    With ActiveSheet
'        LC = .Cells(1, .Columns.Count).End(xlToLeft).Column
'    End With
'    'MsgBox LastCol
''End Sub
    ' Create Table
    oWs = Nothing
    oWB = Nothing
    oExcelApp = Nothing
End Sub
	Try
		oXL = GetObject( "Excel.Application")
	Catch
	Catch
		Exit Function
	End Try
	Return oXL
End Function
Message 4 of 12
A.Acheson
I gave this a shot and couldn't work it out even with multiple stack overflow searches. The options may not be available.
What does work is simply adding the listobject with no options. It seems all the default options work to create the table.
oWs.ListObjects.Add()
 I hope that helps.
Regards
Alan
Message 5 of 12
fidel.makatiaD5W7V
Hi @checkcheck_master , find these sample code i made sometimes back that creates an ipart and an excel table for it
Just thought i should put it here even for other readers
    Public Sub CreateiPart()
        Dim oPartDoc As PartDocument
        oPartDoc = _InvApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject,
                   _InvApplication.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject),
                   True)
        oPartDoc.SaveAs("C:\Temp\APIPart.ipt", False)
        Dim oTG As TransientGeometry
        oTG = _InvApplication.TransientGeometry
        Dim oCompDef As PartComponentDefinition
        oCompDef = oPartDoc.ComponentDefinition
        Dim oPoints(3) As Point2d
        oPoints(0) = oTG.CreatePoint2d(0, 0)
        oPoints(1) = oTG.CreatePoint2d(5, 0)
        oPoints(2) = oTG.CreatePoint2d(5, 5)
        oPoints(3) = oTG.CreatePoint2d(0, 5)
        Dim oSketch As PlanarSketch
        oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(1))
        Dim oLines(3) As SketchLine
        oLines(0) = oSketch.SketchLines.AddByTwoPoints(oPoints(0), oPoints(1))
        oLines(1) = oSketch.SketchLines.AddByTwoPoints(oLines(0).EndSketchPoint, oPoints(2))
        oLines(2) = oSketch.SketchLines.AddByTwoPoints(oLines(1).EndSketchPoint, oPoints(3))
        oLines(3) = oSketch.SketchLines.AddByTwoPoints(oLines(2).EndSketchPoint, oLines(0).StartSketchPoint)
        Dim oProfile As Profile
        oProfile = oSketch.Profiles.AddForSolid
        Dim oExtrude As ExtrudeFeature
        oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, 15,
                        PartFeatureExtentDirectionEnum.kPositiveExtentDirection,
                        PartFeatureOperationEnum.kNewBodyOperation, 0)
        oExtrude.FeatureDimensions(1).Parameter.Name = "Length"
        oExtrude.FeatureDimensions(2).Parameter.Name = "TaperAngle"
        Dim oFactory As iPartFactory
        oFactory = oCompDef.CreateFactory
        Dim oWS As Microsoft.Office.Interop.Excel.Worksheet
        oWS = oFactory.ExcelWorkSheet
        oWS.Cells(1, 1) = "Member<defaultRow>1</defaultRow><filename></filename>"
        oWS.Cells(1, 2) = "Part Number [Project]"
        oWS.Cells(1, 3) = "Length<free>150 mm</free>"
        oWS.Cells(1, 4) = "TaperAngle"
        oWS.Cells(2, 1) = "APIiPart-01"
        oWS.Cells(2, 2) = "APIiPart-01"
        oWS.Cells(2, 3) = "150 mm"
        oWS.Cells(2, 4) = "0 deg"
        oWS.Cells(3, 1) = "APIiPart-02"
        oWS.Cells(3, 2) = "APIiPart-02"
        oWS.Cells(3, 3) = "100 mm"
        oWS.Cells(3, 4) = "5 deg"
        oWS.Cells(4, 1) = "APIiPart-03"
        oWS.Cells(4, 2) = "APIiPart-03"
        oWS.Cells(4, 3) = "50 mm"
        oWS.Cells(4, 4) = "10 deg"
        Dim oWB As Microsoft.Office.Interop.Excel.Workbook
        oWB = oWS.Parent
        oWB.Save()
        oWB.SaveAs("C:\Temp\Test.xls")
        oWB.Close()
        oPartDoc.Update()
        oPartDoc.Save()
    End Sub
Fidel Makatia
Developer Advocate
href=https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-0BD48573-7193-4285-87B7-6727555D053E rel= "noopener noreferrer">Inventor 2022 Documentation |
Message 6 of 12
checkcheck_master
Thank you Fidel for your message.
Although I think this is a different type of Table, your code does look very interesting.
However, I can't get it to work, see screenshots.
Can you tell me how I can get it to work?
Message 7 of 12
checkcheck_master
Thank you A.Acheson for your response and sorting it out.
Indeed this just works.
I still had hope that:
'Imports Microsoft.Office.Interop.Excel.Constants '
would make a difference, but it wouldn't.
Message 8 of 12
WCrihfield
Just an additional link about the Worksheet.ListObjects property.  It seems like, to use that resource we may need to include more References and/or Imports.  The online documentation page for that in Microsoft's site only shows it being used by C#, and says that is used by Visual Studio Tools for Office.  It shows the 'Namespace' and the 'Assembly' (.dll file) where it is sourced from.  You might be able to use that info to include its recognition / functionality within the iLogic rule.   I have never tried using that specific property or object type before, so I just left that part of the code alone for now.
Wesley Crihfield
Message 9 of 12
checkcheck_master
Thanks, good to know.
Apart from that, it is still a challenge for me to program against Excel in iLogic/VB.net.
You can find everything for VBA, but a lot less for VB.net.
The impression is often created that people are talking about VB.net, which turns out to be secretly VBA.
For example, I try to find the Column with header 'Item QTY' through code, but I can't manage it.
This worked fine in VBA using:
' Find column number and letter 'Item QTY'
Dim lQTY As Long
lQTY = FindColumn(oExcelApp, oWB, "Item QTY")
If lQTY = 0 Then
Call MsgBox("Column Item QTY missing.", vbCritical, "ExportBOM")
'Filter = Nothing
Exit Sub 'Function
End If
Private Function FindColumn(ByVal oExcelApp As Excel.Application, ByVal oWB As Workbook, ByVal strColumn As String) As Long
Dim lLastColumn As Long
lLastColumn = oExcelApp.Cells(1, oWB.ActiveSheet.Columns.Count).End(xlToLeft).Columns.column
Dim's As Long
Dim rCells As Range
For s = lLastColumn To 1 Step -1
Set rCells = oExcelApp.Cells(1, s)
If rCells.value = strColumn Then
FindColumn = s
Exit For
End If
Next s
End Function
What else needs to be done in iLogic/VB.net to get this to work?
Message 10 of 12
WCrihfield
Just from a first glance, without digging into it yet, I can already see two potential problems in the code you just posted.
Dim's As Long
should be like this:
Dim s As Long
and in this next line:
you need to get rid of the 'Set' keyword at the beginning of the line, because that is pretty much only used in VBA.
I also think it is a little odd to be using the 'Cells' property directly from the Excel.Application object.  Usually that is called from a Worksheet object directly (avoids confusion of which Workbook and which Worksheet it should be focusing on), or from a Range object directly.  Also, within the same line of code (setting the value of 'ILastColumn'), I see a variable being used 'xlToLeft', within the End() call, but I do not see where that variable is being passed to that Function, or where it is being defined before that point within that Function.  So, I don't if that variable has any value/meaning there.  I also see that that Function (FindColumn) is supposed to return a Long type value, but I don't see anywhere within that function where it is supposed to 'Return' any value.  And all the 'Input' variables are ByVal, instead of ByRef, so I don't think a value could be returned that way either.  Also, you generally don't need to use the keyword 'Call' in iLogic.
Wesley Crihfield
Message 11 of 12
A.Acheson
Regards
Alan
Message 12 of 12
A.Acheson
I response to the ipart table question earlier. The original code is missing the correct application object for inventor.
_InvApplication =ThisApplication
Link to what this means
Regards
Alan
