iLogic create BOM yourself based on a separate collection of Parts in a Dictionary
checkcheck_master
checkcheck_master
Hello.
I would like to make a BOM based on a separate collection of Parts that are not in an assembly but in a dictionary.
For example, the dictionary is of type Document String so the document and all his data is available from the dictionary.
In this way I already export from the dictionary to jpg, stp, pdf and dwg.
It seems to me that exporting to Excel should also work, but I'm not sure how.
From other code I know about Import BOM Customization.
Those seem to me to be two major components that are needed for this.
The dictionary btw has been filled while going through BOMView.
But then I don't know anymore, any tip is more than welcome.
Thanks in advance.
A.Acheson
You would just open excel and loop through dictionary and assign each to a cell. No special export function required. Can you post the code your using?
Regards
Alan
checkcheck_master
@ A.Acheson
Thanks for your reaction.
See code, total code is a sloppy 3000 lines which I won't bore you with.
This is pretty much the core in the Main sub where finally the filled dictionaries are treated.
I've been advised to shorten things before, but I'm not sure how.
On the other hand, I think, there is also a lot happening, then such a rule will automatically become longer.
As for 'You would just open excel and loop through dictionary and assign each to a cell.'
I would like to have an Excel in the Inventor BOM style, just like that.
Picture and then columns with data.
Can such a row be filled in one go when I go through the BOMView or does it really have to be cell by cell?
I think I came across a BOMRow an Export there, is it suitable for that?
How can I open Excel from Inventor, are there multiple ways one of which is the best?
															' 1ste BOM loop, based on the BOM, create Lists en calculate string lenghts to make a more clear overview
															' Take the 'Model Data' BOM to have also the Phantom Components
														    BOM_First_Loop_Get_ListsData_TotalQTY_LengthsData(oBOMView.BOMRows)
															' 2nd BOM Loop, create Files and Folders for the output
															BOM_Second_Loop_fill_Dictionaries_and_TotalQTY(oBOMView.BOMRows, 1)
															' Publish earlier created Lists at the end of the overview
															'Publish_Lists
															' Publish the Dictionaries and check for file lengths
															' Inform user when file lengths exeeds the maximum and stop procedure
															' PAY ATENTION: Check de descripton in the Declaration Section from this rule (search for Check_for_maxFileLength)
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine("Summary Processed Dictionaries:")
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine("Assemblies Combined Production Output - " & DictionaryCombinedProductionOutput.count & "x")
															sw.WriteLine
															For Each pair As KeyValuePair(Of String, Integer) In DictionaryCombinedProductionOutputReadable
																sw.WriteLine(pair.Key & " - " & pair.Value & "x")
															Next
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine("Weldments - " & DictionaryWeldments.count & "x")
															sw.WriteLine
															For Each pair As KeyValuePair(Of String, Integer) In DictionaryWeldmentsReadable
															Next
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine("Parts - " & DictionaryParts.count & "x")
															sw.WriteLine
															For Each pair As KeyValuePair(Of String, Integer) In DictionaryPartsReadable
															Next
'											oProgressBar.Close
'											sw.close
'											ThisDoc.Launch(Control_and_Debugging_log_file)
'											Exit Sub
															' Process the Dictionaries to the Dictionaries_***_Publish
															' These Dictionaries_***_Publish will be filled with the final output name including the Quantity needed in the Project
															' This gives the opportunity to get a good idea of what will be published and to be able to act on possible errors in advance
															' Here the assemblies are broken down
															' The, in the assemblies, used Weldments and Parts are subtracted from the Total Quantity to come to the right amount for the Other Parts Collections
															For Each pair As KeyValuePair(Of Document, Integer) In DictionaryCombinedProductionOutput
																Dim oDoc As Document = pair.Key
																Try
																	Fill_DictionaryCombinedProductionOutputPublish(oDoc, pair.Value)
																Catch ex As IOException
																	If MsgBox("Exception: " & ex.StackTrace & vbNewLine & "Continue?", vbYesNo & vbCritical, "InventorPLUS") = vbNo Then Exit Sub
																End Try
															Next
															For Each pair As KeyValuePair(Of Document, Integer) In DictionaryWeldments
																	logger.debug("=============== oDoc.FullFileName: " & oDoc.FullFileName)
																Try
																	Fill_DictionaryWeldmentsPublish(oDoc, pair.Value)
																End Try
															Next
															For Each pair As KeyValuePair(Of Document, Integer) In DictionaryParts
																Try
																	Fill_DictionaryPartsPublish(oDoc, pair.Value)
																End Try
															Next
															' Check for maxFileLength
															If Log_List_File_Lengths.count = 0 Then
																' No exeeding file lengths, continue
															Else
																log.WriteLine
																log.WriteLine
																log.Write("Files with to long file names: " & Log_List_File_Lengths.count & "               (maxFileLength is set to: " & maxFileLength & ")"  & vbNewLine & vbNewLine)
																	For Each item In Log_List_File_Lengths
																		log.WriteLine(item & "          (Length: " & item.length & ")" )
																	Next
																log.WriteLine
																log.WriteLine
																	MsgBox("Files with to long file names: " & Log_List_File_Lengths.count & vbNewLine & vbNewLine & "Process will be terminated." & vbNewLine & vbNewLine & "Check log for details." , vbCritical, "HML InventorPLUS Production Output")
																	ThisDoc.Launch(Project_Specific_log_file)
																	GoTo Terminated
															' Now we have Dictionairies_Publish with Key as New File Names and Value as Documents to Publish
															' Quantity is at the end of the New File Name between parentheses
															' The new file names where checked for length
															' These separate dictionaries gives us the oportunity to compare what we have on disk with what we gonna put on disk
															' While creating this overview we fill a Dictionary with the Total to publish Documents
															' Also check or the file is In Use / Opened
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine("Summary Processed Dictionaries to files for Final Export:")
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine("Assemblies Combined Production Output - " & DictionaryCombinedProductionOutputPublish.count & "x")
															sw.WriteLine
															For Each pair As KeyValuePair(Of String, Document) In DictionaryCombinedProductionOutputPublish
																sw.WriteLine(pair.Key)
																DictionaryAllFilesToBePublished.add(pair.Key, pair.Value)
																DictionaryAllFilesToBePublishedNoQTY.add(Left(pair.Key, InStrRev(pair.Key, "(") -1),Left(pair.Key, InStrRev(pair.Key, "(") -1))
																'IsFileInUse(pair.Key)
															Next
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine("Weldments - " & DictionaryWeldmentsPublish.count & "x")
															sw.WriteLine
															For Each pair As KeyValuePair(Of String, Document) In DictionaryWeldmentsPublish
															Next
															sw.WriteLine
															sw.WriteLine
															sw.WriteLine("Parts - " & DictionaryPartsPublish.count & "x")
															sw.WriteLine
															For Each pair As KeyValuePair(Of String, Document) In DictionaryPartsPublish
															Next
															log.WriteLine
															log.WriteLine("All Files to be Published: " & DictionaryAllFilesToBePublished.count)
															log.WriteLine("All Files on Disk        : " & DictionaryAllFilesOnDisk.count)
															log.WriteLine
'															' Debug
'															log.WriteLine
'															log.WriteLine
'															log.WriteLine
'															For Each pair As KeyValuePair(Of String, String) In DictionaryAllFilesOnDisk
'															log.WriteLine("DictionaryAllFilesOnDisk pair.Key)  : " & pair.Key)
'															log.WriteLine("DictionaryAllFilesOnDisk pair.Value): " & pair.Value)
'															Next
'															log.WriteLine
'															log.WriteLine
'															log.WriteLine
'															' Debug
'															For Each pair As KeyValuePair(Of String, Document) In DictionaryAllFilesToBePublished
'															log.WriteLine("DictionaryAllFilesToBePublished pair.Key)  : " & pair.Key)
'															log.WriteLine("DictionaryAllFilesToBePublished pair.Value): " & pair.Value.FullFileName)
'															Next
'															log.WriteLine
'															log.WriteLine
'															log.WriteLine
															' Compare the Output before Exporting en determine what needs to be exported
																' FOR HELP: Check if Dictionary Contains Key: DictionaryAllFilesOnDisk.ContainsKey(pair.Key)
																' FOR HELP: Get Dictionary Value for given Key: Dictionary_Total_QTY.Item(oDoc.FullFileName)
																'If DictionaryAllFilesOnDisk.ContainsKey(pair.Key) Then ' File exist on Disk
																If DictionaryAllFilesOnDisk.ContainsKey(Left(pair.Key, InStrRev(pair.Key, "(") -1)) Then ' File exist on Disk
																	'DictionaryAllFilesToBePublished.remove(pair.Key) !!!!!!!!!!
																	' It looks like a Dictionary don't like it when Keys are removed while it's been processed with a For Each loop
																	' Therefore as alternative created another Dictionary that is be filled instead of items removed
																	' So, the file exist on disk, compare if the QTY we need is the same as the QTY on disk
																	If GetQTYfromStr(pair.Key) = GetQTYfromStr(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)))
																		' QTY is the same, do nothing
																		'log.WriteLine
																		'log.WriteLine(pair.Value.FullFileName & " - " & GetProp(pair.Value, "DTP", "Description"))
																		'log.WriteLine(pair.Key)
																		'log.WriteLine("   Quantity was: " & DictionaryAllFilesOnDisk.item(pair.Key) & "x, now: " & GetQTYfromStr(pair.Key) & "x")
																	ElseIf GetQTYfromStr(pair.Key) <> GetQTYfromStr(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)))
																		log.WriteLine
																		log.WriteLine(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)))
																		log.WriteLine("   Quantity changed from: " & GetQTYfromStr(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1))) & "x to: " & GetQTYfromStr(pair.Key) & "x")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)))
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & ".jpg")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & ".stp")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & ".pdf")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & ".dwg")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & "_Sheet_1.dwg")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & "_Sheet_2.dwg")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & "_Sheet_3.dwg")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & "_Sheet_4.dwg")
																		System.IO.File.Delete(DictionaryAllFilesOnDisk.item(Left(pair.Key, InStrRev(pair.Key, "(") -1)) & "_Sheet_5.dwg")
																		' Add to the Final Output Dictionary
																		DictionaryFinalOutputAllFiles.add(pair.Key, pair.Value)
																Else
																	log.WriteLine("File added: " & pair.Key)
															Next
															log.WriteLine
															' Compare if there are files on disk who are not in DictionaryAllFilesToBePublished, they can be removed
															log.WriteLine
																If DictionaryAllFilesToBePublishedNoQTY.ContainsKey(pair.Key) Then
																	' File on disk can stay, compare age...
																	'log.WriteLine("DictionaryAllFilesToBePublished.ContainsKey(pair.Value): " & DictionaryAllFilesToBePublished.ContainsKey(pair.Value))
																	'log.WriteLine("DictionaryAllFilesOnDisk pair.Value: " & pair.Value)
																Else
																	log.WriteLine("File removed: " & Left(pair.Value, Len(pair.Value) -4))
																	'System.IO.File.Delete(pair.Value)
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & ".jpg")
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & ".stp")
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & ".pdf")
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & ".dwg")
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & "_Sheet_1.dwg")
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & "_Sheet_2.dwg")
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & "_Sheet_3.dwg")
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & "_Sheet_4.dwg")
																	System.IO.File.Delete(Left(pair.Value, Len(pair.Value) -4) & "_Sheet_5.dwg")
															Next
															log.WriteLine
															If DictionaryFinalOutputAllFiles.count = 0 Then
																log.WriteLine("All files are up to date.")
																log.WriteLine
																' Progress Bar settings
																oProgressBar.Message = "Calculating Finished"
															Else
																oSteps_Progress_Bar = DictionaryFinalOutputAllFiles.count
																Dim i As Integer
																For Each pair As KeyValuePair(Of String, Document) In DictionaryFinalOutputAllFiles
																	' Progress Bar, update the Message shown within the Progress Bar with each loop.
																	oProgressBar.Message = "Processing Documents " & i & " Of " & oSteps_Progress_Bar & "   " & pair.Value.DisplayName & " - " & GetProp(pair.Value, "DTP", "Description")
																		' Debugging mode, check Main Sub
																		If Debugging Then Exit For
																				ExportToSTEP(pair.Value, pair.Key, GetQTYfromStr(pair.Key))
																				PDF_and_DWG_Exporter(pair.Value, pair.Key)
																	sw.WriteLine("Updated file: " & pair.Key)
																	sw.WriteLine
																	' Update the Progress Bar
																	oProgressBar.UpdateProgress
																	i = i +1
																Next
																sw.WriteLine("Updated files: " & DictionaryFinalOutputAllFiles.count)
																sw.WriteLine
'															' Export the Dictionairies to Image, STEP, PDF and DWG
'															For Each pair As KeyValuePair(Of String, Document) In DictionaryCombinedProductionOutputPublish
'																' Debugging mode, check Main Sub
'																If Debugging Then Exit For
'																		ExportToSTEP(pair.Value, pair.Key, GetQTYfromStr(pair.Key))
'																		PDF_and_DWG_Exporter(pair.Value, pair.Key)
'															Next
'															For Each pair As KeyValuePair(Of String, Document) In DictionaryWeldmentsPublish
'															Next
'															For Each pair As KeyValuePair(Of String, Document) In DictionaryPartsPublish
'																	'logger.info("QTY: " & QTY)
'															Next
															' Delete all empty folders
															For Each item In System.IO.Directory.GetFiles(sProject_PO_Folder, "*.jpg", System.IO.SearchOption.AllDirectories)
															Next
checkcheck_master
Hello.
I manage to create an Excel and fill it with data.
What will not work is to get the thumbnail to the Excel using iLogic.
On the other hand, it is possible to create a jpg of a Part of Assembly using: oDoc.SaveAs(NewImageFileName, True)
This should work, but I get errors:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/getting-the-part-assembly-thumbnail/...
Type 'stdole.IPictureDisp' is not defined.
'Compatibility' has not been declared. It may be inaccessible due to its protection level.
See screenshot.
Public Function iThumbnail(FilePath As String) As System.Drawing.Image
	If Not System.IO.File.Exists(FilePath) Then Return Nothing
	Dim oImg As System.Drawing.Image = Nothing
	Try
		Dim iApp As New Inventor.ApprenticeServerComponent
		Dim oDoc As Inventor.ApprenticeServerDocument = iApp.Open(FilePath)
		Dim SummaryInfo As Inventor.PropertySet = oDoc.PropertySets.Item("Inventor Summary Information")
		Dim ThumbProp As Inventor.Property = SummaryInfo.Item("Thumbnail")
		Dim Thumbnail As stdole.IPictureDisp = CType(ThumbProp.Value, stdole.IPictureDisp)
		If Not Thumbnail Is Nothing Then
			oImg = Compatibility.VB6.IPictureDispToImage(Thumbnail)
		oDoc.Close()
		iApp.Close()
	Catch Ex As Exception
		MsgBox(ex.Message)
	End Try
	Return oImg
End Function
