iLogic - Count specific part in pattern
I try to count a specific part in iam rectangular pattern
Here's my idea of code:
i = 0
oCaisson40 = ThisApplication.Documents.ItemByName(oPath40)
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("Pattern-A")
oElement = oPattern.OccurrencePatternElements.Item(oCaisson40)
oComp = oPattern.Occurrences.Item(1)
For Each oComp In oPattern
i = i+1
Next
oNomDernierCaisson1 = i
Thanks for your help
ok i try with an another code if anyone can help me
i = 0
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("Pattern-1")
Dim oOccs40 As ComponentOccurrencesEnumerator
oOccs40 = oAsmCompDef.Occurrences.AllReferencedOccurrences(oCaisson40)
Dim oOcc40 As ComponentOccurrence
For Each oOcc40 In oPattern.Occurrences
If oOcc40.Name = oOccs40 Then
i = i+1
Else
Next
Owner2229
Hi, try this one below. Fill in the Occurence name you're searching for and run it.
It will go throught the assembly and all sub-assemblies.
Sub Main()
    oName = "MySearchedPartName" 'Without extension
    Dim oDoc As Document = ThisApplication.ActiveDocument
    SubAsm(oDoc.ComponentDefinition.Occurrences)
    MsgBox(oCount)
End Sub
Private oName As String
Private oCount As Integer
Sub SubAsm(oOccs As ComponentOccurrences)
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oOccs
        Dim OcName As String = oOcc.Name
        OcName = Left(OcName, InStrRev(OcName, ":", -1) - 1)
        If OcName = oName Then oCount = oCount + 1
        Dim oDoc As Document = oOcc.Definition.Document
        If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
    Next
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Thanks Mike,
your code count all specific part in all the assembly,
my problem is to count specific part in only one specific pattern named "Pattern-A"
have you an idea to do this ?
thanks
Owner2229
Here you go:
Sub Main()
    Dim OPS As OccurrencePatternElements = oDoc.ComponentDefinition.OccurrencePatterns.Item("Pattern-1").OccurrencePatternElements
    Dim OP As OccurrencePatternElement
    For Each OP In OPS
        SubAsm(OP.Occurrences)
    Next
    MsgBox(oCount)
End Sub
Sub SubAsm(oOccs As ComponentOccurrencesEnumerator)
    Next
End Sub
Mike
Thanks a lot Mike
Your code is what I need
Yan
Owner2229
You're welcomed Smiley Happy
Mike
