iLogic copy user parameters from parts to assembly
jishee
Message 1 of 17
jishee
Using iLogic, I want to be able to copy user parameters from part files into an assembly. I found an example that copies user parameters from an assembly into part files and tried modifying it to suit my needs and it runs without errors but does not copy over any of the user parameters. The code I have is below.
Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document
For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments
	'Look for part documents.
	If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
    	Dim partDoc As Inventor.PartDocument = refDoc
    	Dim refDocUserParams As UserParameters = refDoc.ComponentDefinition.Parameters.UserParameters
        'Add the part parameters to the assembly.
        For Each partUserParam As UserParameter In refDoc.ComponentDefinition.Parameters.UserParameters
            'Check to see if the parameter already exists.
            Dim checkParam As UserParameter = Nothing
            Try
            	checkParam = refDocUserParams.Item(partUserParam.Name)
            Catch ex As Exception
            	checkParam = Nothing
            End Try
            If checkParam Is Nothing Then
				'Create the missing parameter.
            	refDocUserParams.AddByExpression(partUserParam.Name, partUserParam.Expression, partUserParam.Units)
			Else
            	'Update the value of the existing parameter.
            	checkParam.Expression = partUserParam.Expression
		Next
Next
 Any help with what I am doing wrong is appreciated.
Replies (16)
Message 2 of 17
marcin_otręba
change
into
Dim refDocUserParams As UserParameters = asmdoc.ComponentDefinition.Parameters.UserParameters
 and move it above
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 17
jishee
I know get a 'Parameter is incorrect' error. It runs until the line highlighted below.
Message 4 of 17
JhoelForshav
Hi @jishee
Adding by expression might not always work. The expression could contain a name of a parameter that doesn't exist in the assembly. Either a user parameter that hasn't been copied yet or a model parameter.
My suggestion is to try to use the expression but if it fails, use the parameter value instead:
Dim refDocUserParams As UserParameters = asmDoc.ComponentDefinition.Parameters.UserParameters
            Try
            Catch
            End Try
				Try
				Catch
				refDocUserParams.AddByValue(partUserParam.Name, partUserParam.Value, partUserParam.Units)
				End Try
			Else
				Try
				Catch
				checkParam.Value = partUserParam.Value
			End Try
		Next
Next
Message 5 of 17
marcin_otręba
@JhoelForshav  have right that reason must be in missing parameter from expression.
If you really must add expression then you can start with this code if you want to determine wchich parameter missing:
	'If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
    	Dim partDoc As Inventor.Document = refDoc
            Try
            Catch
            End Try
				Dim checkParamdependants As Parameter = Nothing
					Dim pardependants As String = ""
					For Each param As Parameter In refDoc.ComponentDefinition.Parameters
						If param.Type <> 50348800 Then
							If param.Dependents.count>0 Then
						For Each paramdep As Parameter In param.Dependents
						If paramdep.name = partUserParam.Name Then
					Try
			            	checkParamdependants = refDocUserParams.Item(param.Name)
			            Catch
			            '	If pardependants.Contains(param.name)=False Then
							pardependants = pardependants  & param.name & ";"
					'	End If
			            End Try
					Next
				Next
			Try
			If pardependants = "" Then
			Else
				MessageBox.Show("Error, in assembly dependant parameters missing: " & pardependants)
			Catch
			 MessageBox.Show ("Error, in assembly dependant parameters missing: " & pardependants )
				End Try
			Else
				Try
				Catch
			End Try
		Next
'	End If
Next
Message 6 of 17
jishee
@JhoelForshav it works correctly now. Thank you for your help!
Thank you also @marcin_otręba !
Message 7 of 17
robertast
good afternoon @JhoelForshav
Can you tell me which iLogic can transfer all user parameters from the assembly to all the part in this assembly?
in advance
thank you so much
Message 8 of 17
JhoelForshav
Hi @robertast
The type of parameter copy that's done in this thread, but from assembly to all its parts would look something like this:
iLogicVb.UpdateWhenDone = True
Dim oAsm As AssemblyDocument = ThisDoc.Document
For Each oDoc As Document In oAsm.AllReferencedDocuments
	If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject AndAlso oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count > 0
		Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
		For Each oParam As Inventor.Parameter In oAsm.ComponentDefinition.Parameters.UserParameters
			Dim paramInPart As Inventor.Parameter
			Try
				paramInPart = oDef.Parameters.UserParameters.Item(oParam.Name)
				Try
					paramInPart.Expression = oParam.Expression
				Catch
					paramInPart.Value = oParam.Value
				End Try
			Catch
				Try
					oDef.Parameters.UserParameters.AddByExpression(oParam.Name, oParam.Expression, oParam.Units)
				Catch
					oDef.Parameters.UserParameters.AddByValue(oParam.Name, oParam.Expression, oParam.Units)
				End Try
			End Try
		Next
Next
Message 9 of 17
robertast
@JhoelForshav
Thank you very much, I am your debtor
Message 10 of 17
robertast
@JhoelForshav
But when it’s good, it wants more.🤗  But is this most likely impossible?  🤔
If SUBASSEMBLY appears in ASSEMBLY, it passes parameters to all parts, including SUBASSEMBLY parts.
And he wants the ASSEMBLY to switch over to its parts, and not to trade SUBASSEMBLY. SUBASSEMBLY on their part.
Is it possible? If yes - the wine is from me...
Message 11 of 17
JhoelForshav
@robertast
Thats possible for sure. Only problem will be if the same part exists in multiple subassemblies...
I’ll probably not get home in time to write this code tonight. But if no one beats me to it i’ll fix it tomorrow😊
Message 12 of 17
JhoelForshav
@robertast
Here you go 🙂
Sub Main
	Dim asm As AssemblyDocument = ThisDoc.Document
	copyParams(asm)
End Sub
Sub copyParams(oAsm As AssemblyDocument)
	For Each oDoc As Document In oAsm.ReferencedDocuments
		If oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count > 0
					Try
						Try
						Catch
						End Try
					Catch
						Try
						Catch
						End Try
					End Try
				Next
			ElseIf oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
				'if the referenced document is an assembly
				'the sub will call itself with that document as the argument
				copyParams(oDoc)
	Next
End Sub
Message 13 of 17
robertast
@JhoelForshav
Something went wrong, the code swears ... 🙄
Message 14 of 17
robertast
Everything is in order, you must disable the "Straight VB code"Thanks again
Message 15 of 17
donaldleigh
Hi @JhoelForshav
Just come across your reply here, If you only wanted certain parameters from certain parts in the assembly how would you do that please.
Eg, say we have "Parameter1" in the part "PartA" and I would like to copy this "Parameter1" to the assembly that contains "PartA"
Cheers
Donald
Message 16 of 17
alan.wedge
I am having issues with this code, im getting this error:
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
any idea what this could be?
Message 17 of 17
damian_dymczyk
Hi GREAT WORK again!
I'm wondering is there a chance that instead of all the occurrences parameters would be only added from selected one ?
