iLogic: Controlling part adaptivity
Log0ut
Log0ut
Example: I have two parts in my assembly: part1 and part2
How i can turn adaptivity on, for tehese parts, using ilogic?
mdavis22569
You'd likely need to have the iLogic have the name / file name - identification in the coding.    If not, you could have it "prompt" you for it.
But I really don't see it as being any faster than turning it on / off yourself.
(from the limited information shared)
Mike Davis
Log0ut
Found solution:
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
For Each oPart In oDoc.ComponentDefinition.Occurrences
	If oPart.Name = "Part1" Then
		oPart.Adaptive = True
	Else If oPart.Name = "Part2" Then
Next
johnsonshiue
Hi! Please note that the adaptive relationship only exist within the context of the assembly. So, the adaptive parts cannot be adaptive in another assembly. At the moment, Inventor does not support flexible parts (a part with undetermined length).
Many thanks!
Software Test Engineer
