ilogic configuration problem in inventor 2016?
Message 1 of 27
hi!
we have just installed inventor 2016 but the rule who created my partist dont work now, but work great in inventor 2015, the problem is do not keep the vb macro in my excel sheet???
Thanks for your help!
Replies (26)
Message 21 of 27
i change the iColStart to 10 for col "t" in excell and exportto col "A"?
Message 22 of 27
ok work really great thanks again Adam 🙂
Message 23 of 27
Again a quetion!
I have a little problem, all invisible row in the partlist is exported, it's possible to dont exported the invisible row???
Message 24 of 27
Again a question!
Message 25 of 27
Hi Adam
Again a question!
I have a little problem, all the invisible row in the partlist is exported, it's possible to dont export the invisible row???
Message 26 of 27
adam.nagy
Autodesk Support
Autodesk Support
Hi Serge,
The forum was down when I tried to answer.
You just have to investigate the properties of the objects you are dealing with:
http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
E.g. in this case check the PartsListRow object: it has a Visible property which I think is exactly for that.
See modified code with the difference highlighted in red:
Sub ExportPartsListContent()
  Dim oExcel As Object
  Set oExcel = CreateObject("Excel.Application")
  ' For debugging
  'oExcel.Visible = True
  Dim oWB As Object
  Set oWB = oExcel.Workbooks.Open("C:\temp\test.xlsm")
  Dim oWS As Object
  Set oWS = oWB.ActiveSheet
  Dim oDoc As DrawingDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oSheet As Sheet
  Set oSheet = oDoc.ActiveSheet
  ' Export the first PartsList
  Dim oPL As PartsList
  Set oPL = oSheet.PartsLists(1)
  ' Starting cell position on the Excel sheet
  Dim iRowStart As Integer: iRowStart = 1
  Dim iColStart As Integer: iColStart = 1
  ' Export headers
  Dim iRow As Integer: iRow = iRowStart
  Dim iCol As Integer: iCol = iColStart
  Dim oCol As PartsListColumn
  For Each oCol In oPL.PartsListColumns
    oWS.Cells(iRow, iCol).Value = oCol.Title
    iCol = iCol + 1
  Next
  iRow = iRow + 1
  ' Export content
  Dim oRow As PartsListRow
  For Each oRow In oPL.PartsListRows
    If oRow.Visible Then
      iCol = iColStart
      Dim oCell As PartsListCell
      For Each oCell In oRow
        oWS.Cells(iRow, iCol).Value = oCell.Value
        iCol = iCol + 1
      Next
      iRow = iRow + 1
  Next
  ' Save it
  ' We disable the confirmation dialog
  ' in case the file already exists and
  ' needs to be overwritten
  oExcel.DisplayAlerts = False
  Call oWB.SaveAs("C:\temp\test2.xlsm")
  ' Close excel
  Call oExcel.Quit
End Sub
Cheers,
Adam Nagy
Autodesk Platform Services
Message 27 of 27
i imagine that 😉
thank you very much again Adam 🙂
