ilogic configuration dialog won't save settings
snappyjazz
snappyjazz
We have external ilogic rules that update properties and parameters; most of which update the titleblock. For one of our users these rules aren't running when they should. So I checked their event triggers and they're empty. This shouldn't be so because we share the same "RulesOnEvents.xml" via the vault. I checked their version of the xml and its correct; it has all of the external rules listed under the right event trigger. So I check their ilogic configuration dialog (see below). For some reason they have two directories listed instead of just our shared directory. They have the default listed first, then our shared directory second. According to the help for this dialog, inventor reads the xml in the first directory. I think this might be why his ilogic triggers aren't correct. So I tried removing the top directory, but the dialog doesn't keep the change. Every time we remove it and restart inventor it's still there. How do I get the dialog to keep the change?
snappyjazz
We tested a couple of times to get that dialog to save our settings and failed. Fast forward to today and it has sorted itself out. Only our shared location is in the dialog, and the event triggers now show up in the right places. I didn't do anything else, so this seemed to have fixed itself.
