iLogic components
iLogic components
fridtjofZM5ME
iLogic components
fridtjofZM5ME
When you place a bolt from the Content Center into an assembly, the bolt automatically changes size to the dimension corresponding to the dimension of the hole the cursor hovers over. How do you create the same behaviour for a custom iLogic component that features a threaded shaft?
Michael.Navara
In my opinion this is not a built-in functionality. You need to handle this yourself. Useful may be en SelectEvents
You need to check what is PreSelected, modify the preview, update parameters, check the pre-selected entity is valid etc.
It is not easy task.
